Question for all honda gods?
Old Dec 31, 2006 | 10:29 AM
ef-hatchcrap's Avatar
Default Question for all honda gods?
Is there any crx si or d series manual tranny that has lsd? I will get my tranny numbers if needed thanks
Old Dec 31, 2006 | 10:33 AM
dr_latino999's Avatar
Default Re: Question for all honda gods? (ef-hatchcrap)
Some of the ZC transmissions came with a LSD, but these were the Later Hydro S20 transmissions. I can't remember if there was a cable LSD.
Old Dec 31, 2006 | 10:38 AM
Default Re: Question for all honda gods? (dr_latino999)
Ok appreciate the info but still need a deffinate answer. Reason being I did a burnout in my car today with a new tranny and both frint tires started spinning the whole time.
When I chirp second gear both tires spin too.
Old Dec 31, 2006 | 10:50 AM
ttt
Old Dec 31, 2006 | 11:05 AM
cbp_crx's Avatar
I dont think there is other than the zc tranny that has them. When I do a burnout, it spins both tires also, but I dont have a lsd either.
Old Dec 31, 2006 | 11:06 AM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap &raquo;</TD></TR><TR><TD CLASS="quote">Ok appreciate the info but still need a deffinate answer. Reason being I did a burnout in my car today with a new tranny and both frint tires started spinning the whole time.
When I chirp second gear both tires spin too.</TD></TR></TABLE>
Sometimes it just catches. I've done one wheel peels, and spun 'em both.
Old Dec 31, 2006 | 11:11 AM
Default Re: Question for all honda gods? (Tippyman)
Yeah me 2 but when I go around a corner and punch it both front tires spin no matter what both of my front tires spin like I have lsd.
Either way I dont care but if I have lsd is on like donkey kong
Old Dec 31, 2006 | 11:16 AM
Tippyman's Avatar
I'll tell you a definite way to tell. Pull the axles out of the tranny and look through the differential. If you can see all the way through with no obstructions, you have an LSD. If there is a little bar in the way, you don't have an LSD.
Old Dec 31, 2006 | 11:26 AM
Well I just put the tranny in and I remeber clear as day that you could see all the way through where the axels go.
thanks for the info tippyman, you need to get us a video with you spraying. I have the same car
Old Dec 31, 2006 | 11:32 AM
STREETWERKZ's Avatar
ok.
Old Dec 31, 2006 | 11:33 AM
Tippyman's Avatar
thanks for the info tippyman, you need to get us a video with you spraying. I have the same car</TD></TR></TABLE>
I need to get off my *** and change the jets, lol.
Old Dec 31, 2006 | 01:25 PM
So do it. I have left my car sit for 2 years and finally got it running
Old Jan 6, 2007 | 02:34 PM
StupidSlowRSX's Avatar
No.. There isn't a D series Cable tranny w/ LSD.. There is however, a B series cable tranny with LSD
Old Jan 6, 2007 | 03:05 PM
VtecSyndrome's Avatar
Default Re: Question for all honda gods? (StupidSlowRSX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowRSX &raquo;</TD></TR><TR><TD CLASS="quote">No.. There isn't a D series Cable tranny w/ LSD.. There is however, a B series cable tranny with LSD</TD></TR></TABLE>
So then his LSD is aftermarket I assume?? just wanting to clear it up cuase I am interested in the D-series LSD option also.
Old Jan 6, 2007 | 03:07 PM
SloAssHB's Avatar
Heres a easy way to tell if you have a LSD...Jack the front end up so the tires are off the ground and leave the car in neutral. Spin the tires if both sides rotate the same direction then you have lsd if they dont then its a open diff
4kgst
May 29, 2009 05:47 AM
xx89civicracer89xx
19
Feb 17, 2007 07:10 PM
Busta0990
12
Sep 13, 2005 10:22 PM
Dwight Schrute
Jun 18, 2004 01:13 PM
crxzc
Mar 29, 2002 01:08 AM
