Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Oil Filter for PER-1791 (remote relocation)
Old Dec 31, 2006 | 10:04 AM
Jeff_B's Avatar
Default Oil Filter for PER-1791 (remote relocation)
For those of you using a remote oil filter mount with 3/4 - 16 threads on your oil cooler setups, what oil filter are you using? I know that a Dodge SRT-4 filter will fit, but it is quite a bit bigger than the OEM filter. Any suggestions?
Old Dec 31, 2006 | 12:59 PM
creechrr's Avatar
Default Re: Oil Filter for PER-1791 (Jeff_B)
The VW 1.8T filter will work and is slightly larger than the Honda units.
Old Dec 31, 2006 | 05:08 PM
Boilermaker1's Avatar
I've been using the big Ford Truck Filter PH8A I think, but the PH16 (Taurus) filter also fits, and its half the size of the truck filter. Havent had pressure problems with the big filter, so I'm taking the extra oil capacity.
Old Dec 31, 2006 | 08:26 PM
Track rat's Avatar
Default Re: (Boilermaker1)
I have a remote with a 3/4 x 16 and I've used the following:
Mobil 1 M1-301
Ford FL1A
Fram PH8A
Fram PH16 (same as a PH 8A, but about 1/2 the length)
Old Jan 1, 2007 | 03:04 PM
Lo-Buck EF's Avatar
Default Re: (Track rat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Track rat &raquo;</TD></TR><TR><TD CLASS="quote">I have a remote with a 3/4 x 16 and I've used the following:
Mobil 1 M1-301
Ford FL1A
Fram PH8A
ive used the ph8a, ph16 and one smaller (oem size with correct threads recommended by a miata guy) . the oe size have oil pressure issues. only saw about 40 psi. so i went back the ph series and have had no pressure issues.
mhax
Jul 13, 2014 06:30 PM
Adankid
Jan 1, 2009 03:12 PM
petec59
Honda Civic (2006 - 2015)
16
Apr 19, 2007 12:21 PM
Boilermaker1
May 3, 2005 08:32 PM
EKB18BPR3
11
Aug 18, 2002 11:53 PM
