Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Homemade Intake (installed)
Old Dec 31, 2006 | 01:24 AM
Nighthawk R18's Avatar
Default Homemade Intake (installed)
comments, suggestions, opinions welcome.
so i had a bit of extra cash on me and an extra filter lying around so i decided to make my self an intake
thats what it looks like, only i zip tied the neck of the filter to that metal bar down there (not shown)
its not 100% stable down there. maybe like 80%. where do you think i should permantly set the filter?
also, the stock box is still there. i just took out the stock filter and some oem piping and replaced it with my air duct. i kept the stock intake box for the sake of the MAF adaptor.
without the intake box..
Connected MAF sensor: idles, 2 sec later. stall
Disconnected MAF sensor: im rev limited at 3.5k rpm
since im running the stock box w/o stock filter, do you think air gets in the edges of the box? if so, any ideas on how to fix that would be awesome.
thanks alot. this whole "homemade intake" may not be much but its something till i get more money for the actual legit intakes..lol
once again..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">comments, suggestions, opinions welcome.
thank you.
Old Dec 31, 2006 | 08:31 AM
WILD_WILL's Avatar
Default Re: Homemade Intake (Nighthawk R18)
LOL sound clips please and on the effort to make it.
Old Dec 31, 2006 | 08:54 AM
kryptonite67's Avatar
Default Re: Homemade Intake (WILD_WILL)
i agree, props on going homemade
Old Dec 31, 2006 | 09:23 AM
iDeNtiTy
Guest
Posts: n/a
in all honesty, your prolly lost hp from that setup.....
nothing beats stock OEM **** unless its a legit intake system.
Old Dec 31, 2006 | 09:24 AM
Type X's Avatar
Default Re: (Type-Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Ek &raquo;</TD></TR><TR><TD CLASS="quote">in all honesty, your prolly lost hp from that setup.....
nothing beats stock OEM **** unless its a legit intake system.</TD></TR></TABLE>
i 100% agree
Old Dec 31, 2006 | 10:13 AM
Think One's Avatar
lol dope.
do you notice any difference when you drive?
mad props yo!
Old Dec 31, 2006 | 11:23 AM
24boosted's Avatar
Old Dec 31, 2006 | 12:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WILD_WILL &raquo;</TD></TR><TR><TD CLASS="quote">LOL sound clips please and on the effort to make it.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kryptonite67 &raquo;</TD></TR><TR><TD CLASS="quote">i agree, props on going homemade</TD></TR></TABLE>
thanks and ill try to get a hold of a device that records sound so i can upload it on the computer.
yea i think air is getting in through the sides of the intake box, since theres no stock filter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">
i 100% agree </TD></TR></TABLE>
any suggestions? except the obvious "buy a legit intake"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowww_DCfour &raquo;</TD></TR><TR><TD CLASS="quote">lol dope.
mad props yo!</TD></TR></TABLE>
its significantly louder anytime when on the throttle.
my first gear seams normal though gain wise.
i seem to go though 2nd and 3rd gear faster, but i don't know it may be all in my head
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24boosted &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
thats cool.
Old Dec 31, 2006 | 12:35 PM
eL's Avatar
eL
That tubing has way too many ripples in it to be any good.
Old Dec 31, 2006 | 12:40 PM
Type X's Avatar
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">That tubing has way too many ripples in it to be any good.</TD></TR></TABLE>
thats first
and better pix if the WHOLE setup, where the intake is sitting etc etc
Old Dec 31, 2006 | 12:57 PM
Declectic's Avatar
here's the problem with that setup...
the pipe you connected the filter too.. is "okay" i suppose but in a bad location really (as far as safety of the moto goes) but more over, that tube leads up to you intake box.. which is just a BOX and when you remove the filter... you'll notice that there is no "direct" flow from the pipe to the box to the intake arm... so the air just gets hella turbulant in there and doens't smoothly FLOW into the intake arm... so really for this whole project to be of ANY effect, you need to put that filter on the end of the intake arm, which just isn't going to happen with the MAF sensor being on the intake box
what CAN you do.. maybe make a pipe that connects the intake arm and tubing that the filter is connected too and put it inside the intake box - (if that makes sense)
Old Dec 31, 2006 | 02:34 PM
RICO_'s Avatar
NO MERCY!
Default Re: (SeanJohn1802)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">here's the problem with that setup...
what CAN you do.. maybe make a pipe that connects the intake arm and tubing that the filter is connected too and put it inside the intake box - (if that makes sense)</TD></TR></TABLE>
WOW! Hey maybe you SHOULD just get a legit intake! Sounds like you're havin some trouble. Just my suggestion though.
Good luck !
Old Dec 31, 2006 | 02:47 PM
Default Re: (eL)
and better pix if the WHOLE setup, where the intake is sitting etc etc</TD></TR></TABLE>
ill get right on that
haha this is what i was thinkin about the whole time i was in church today
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICO_ &raquo;</TD></TR><TR><TD CLASS="quote">
Good luck !</TD></TR></TABLE>
not really having "trouble". just thought that my setup has some flaws that could be improved with the help of HT
Modified by Nighthawk R18 at 4:39 PM 12/31/2006
Old Dec 31, 2006 | 03:48 PM
heres more pis..
engine bay
pipe route..
rubber connector pieces / ghetto MAF Adaptor
Old Dec 31, 2006 | 05:18 PM
24boosted's Avatar
Are you strapped for cash aftering buying the car OR did your parents buy it for you and you don't have a job? It's cool cuz we've all been there at some point (some may have been spoiled) but..
You pretty much said it yourself bro...
Old Dec 31, 2006 | 06:55 PM
eL's Avatar
eL
Does your intake system now have 2 filters?
Old Dec 31, 2006 | 07:32 PM
damn, your good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">Does your intake system now have 2 filters?</TD></TR></TABLE>
no the intake box is empty
Old Dec 31, 2006 | 09:16 PM
eL's Avatar
eL
Whats the point of the intake box then? Shouldnt the "intake" be attached to the tb like any other intake?
Old Dec 31, 2006 | 09:31 PM
Default Re: (eL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eL &raquo;</TD></TR><TR><TD CLASS="quote">Whats the point of the intake box then? Shouldnt the "intake" be attached to the tb like any other intake?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nighthawk R18 &raquo;</TD></TR><TR><TD CLASS="quote">i kept the stock intake box for the sake of the MAF adaptor.
new years
Old Dec 31, 2006 | 10:34 PM
ianwells100's Avatar
mate, i know a lot of ppl are mocking you, well, they have a little bit of reason to do so...
the whole point of an intake is to increase flow/efficiency of the air into the throttle body, with the CAI adding cold, dense air (more oxygen) to the mix.
now, what you have here is a weak intake, that may possibly break off at anytime. not to mention the tubing you have will have ***** flow, the ripples in the tubing will not cause good air flow. additionally, the stock airbox, as discussed above will just cause as another point of turbulance, and as such will decrease air flow.
you have 3 options to improve the situation you're in right now:
1) return hte intake to stock (best bet for you right now)!
2) re-do the intake, with smooth materials (3" PVC -ghetto- piping, or preferably metal piping) and replace the stock airbox with this smooth piping
3) buy a real intake, there are plenty of CAI's and SRI's which will make a huge difference to your current setup.
Either way, i'd strongly suggest you dump your current setup, you have a nice car, please don't ruin it for hte sake of $100/$200 saved on an intake (it'd be much better to return to stock) - also, no i'm not against home made intakes, i've made them before for cars, and they worked very well, as tehy were thought out and engineered well, using the right materials
Old Dec 31, 2006 | 11:06 PM
Default Re: Homemade Intake (ianwells100)
^^ yea truth hurts
im stock right now because im going for a long drive tomorrow and i dont wanna take any chances. i'm taking your, and probably everyone elses advise to return to stock for good, unless i come up with more ideas including getting rid of the box, using un-rippled piping, and something with a legit MAF adaptor. (probably not going to happen).
so my 22$ investment was a fail
but whats trial and error without the error right guys?! lol
Ninja:
FIRST POST OF 2007 WoooOooOoOOOOO
Old Jan 1, 2007 | 02:09 AM
good for you, you've made the best decision there...
take solace (sp?) in that 'nothing ventured, nothing gained' - at least now you know why most of us pay the higehr $$ for the name brand intakes
good luck to you with your mods
Old Jan 1, 2007 | 09:08 PM
Demonis's Avatar
All I can say is... it was probably a waste of time and money. But, not too bad... good creativity.
Old Jan 1, 2007 | 09:13 PM
L-Dawg's Avatar
Default Re: (Demonis)
I think it's cool that he tried, even if it ended up providing nothing more than the learning experience
Old Jan 1, 2007 | 10:12 PM
Type X's Avatar
Default Re: (L-Dawg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by L-Dawg &raquo;</TD></TR><TR><TD CLASS="quote">I think it's cool that he tried, even if it ended up providing nothing more than the learning experience </TD></TR></TABLE>
teggy21
Mar 5, 2006 09:38 PM
amej8
Feb 16, 2006 10:09 PM
User 42624
11
Aug 19, 2005 04:37 PM
Integvalier
Aug 28, 2002 04:15 PM
