JDM SiR Accord headlights for 5th gen: What size bulbs?
I picked up a set of JDM headlights and my OEM headlights do not fit right. Anyone know what I need to get them wired up right?
i believe they're H4's...not too sure if those are the high's or lows...
i was pretty pissed off because when i got mines in...i didnt know the bulb/socket was different so i had to get new bulbs
did you need anything else to make them work. Like you have to wire the light socket differently or something right?
well first you need h4 bulbs...h4 plug for the lights...and you need a Sauder(sp?) to connect the wires together
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XaznkewlguyX »</TD></TR><TR><TD CLASS="quote">did you need anything else to make them work. Like you have to wire the light socket differently or something right?</TD></TR></TABLE>
it depends...my headlights came with a wire harness...so it plugged into my stock ones then converted the ends to H4s and whatever my low or high beams are...
if not...you'll need to cut off the ends and solder them together...
my harness looked something like this...
if you run into any problems..i happen to come across this...luckily...it appears that they sell different wire harnesses...
it was http://www.eaautoworks.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EXccord »</TD></TR><TR><TD CLASS="quote">hmmm, weird, mine came with h4 wires, ended up splicing them together, but yeah like sushi and all the other guys, h4's man</TD></TR></TABLE>
yeah..mines hand plugs on both ends...and i just plugged it into the oem wiring and to the socket...
resurrecting this from the dead, but that link you put in there doesnt work. what was that site called cause I need me some 9006 to h4 sockets.
you can also get 9003 size bulb, which is the same exact size as the H4 only they sell them in pairs. saves a little money. H1 is the high beam, which, in my opinion, doesnt work very well.
crx_ef8
Dec 20, 2002 06:27 AM
