gsr swapped civic.... cheap.... located in WI
93 Honda civic dx coupe.
teal green
95 gsr swap
No intake, header or exhaust, just factory exhaust manifold and does not have a muffler.
Jdm red valve cover
skunk2 adjustable cam sprockets
factory p72 ecu
1 check engine light, #1 cyl position malfunction, It is an aftermarket distributor with a bad sensor, I swapped the distributor with a b16 dist and the code went away. I do have some internal b16 dist guts that I could include.
as far as I know everything is legit.
Good tranny... no grinds brand new shift linkage.
stock clutch
The car needs work.
bumpers, windshield and little things need to be repaired. Would be a great fixer upper.
The interior is in fairly good shape but will need to be cleaned up.
The engine runs and idles good, the TPS does need to be adjusted or replaced.
It bogs down when the gas is fully pressed, if you dont fully press the gas it doesn't bog.
Over all you could put a little money into it and resell it for more if you know how to do body work or just part everything out. I just don't have the time and resources. My e-mail is streettuned@yahoo.com
920-540-5494
asking $2500 OBO
I have pictures but don;t know how to post them on this post as soon as I fond out how I'll put some up other wise just e-mail me for them.
teal green
95 gsr swap
Jdm red valve cover
factory p72 ecu
stock clutch
The car needs work.
920-540-5494
asking $2500 OBO
Deejay232323
Sep 4, 2013 04:55 AM
