huge problem!
Old Dec 30, 2006 | 12:44 PM
coreyhayman's Avatar
Default huge problem!
just got my swap done etc, did it myself....took the car out on the road today and while doing 80km/h my crank pulley flew off, tossed my alternator belt and p/s belt off as well........i figured i was only 5 mins from home so i could drive it there then shut t off and re install the pulley,needless to say the car shut off 2 seconds later and it wont start. I look and the crank etc that holds the timing belt on slipped off causing my timing belt to slip off, now i didnt hear any crazy noises etc. I just re installed the belt and tried to start the car but it wont start, just keeps turning over and over.......any ideas?
Old Dec 30, 2006 | 12:48 PM
bart2546's Avatar
Default Re: huge problem! (coreyhayman)
Timing off maybe? I don't want to sound like an ******* but that sounds pretty bad to me, but for God's sake don't keep trying to start it if it's out of time.
Old Dec 30, 2006 | 12:51 PM
everythings lined up to tdc so it should start up right?iv moved the dizzy around a few times to and still nothing
Old Dec 30, 2006 | 01:49 PM
anyone?
Old Dec 30, 2006 | 05:18 PM
also when the cars in gear and e brake is off the car rolls, so im assuming i fucked the head and theres no compression
Old Dec 30, 2006 | 05:20 PM
I_dont_want_a_user_name's Avatar
Default Re: (coreyhayman)
problay got some bent valves pull the head and check it
Old Dec 30, 2006 | 05:34 PM
jdeemseerx's Avatar
Default Re: (I_dont_want_a_user_name)
you swapped in a d16y8 right? im not sure if it is a clearance motor.. But if your positive everything is top dead center i would check compression. I guess you found your problem from your other thread eh? good luck you could always pull the valve cover off and rotate the crank with a ratchet to see if everything is moving smoothly.. but definately check compression. damn that sucks..
Old Dec 30, 2006 | 05:38 PM
onephatcivic98's Avatar
you probly have bent valves. since its a y8 its ballanced externaly and since the pully came off you are probly garenteed you fucked something up. like they are saying make sure it is in time if it is run compression test. if it fails pull the head and see if you have bent valves wich you probly do.
Old Dec 30, 2006 | 05:45 PM
so if anything i fucked the head, thats a pita cuzz the head gasets are 100 each!
ddn1313
Aug 4, 2018 02:46 PM
Macnotiss
10
Oct 18, 2017 05:44 PM
slowsinglecam
11
Dec 24, 2011 07:59 AM
djtony5
May 5, 2006 09:52 PM
rokestah
Feb 3, 2003 04:20 PM
