How important is this peice?
Old Dec 30, 2006 | 11:07 AM
Exempt's Avatar
Default How important is this peice?
Number 2 in the pic:
I assume its a dust seal of some sort? I changed my axles the other day and I noticed this peice was loose, so loose it kept falling off... So I finally got it to stay in place long enough to bolt the axle in, but when I went to drive the car it sounded like I had a damn cat stuck in my wheel (screeching noise)... So I get it home and jack it up and sure enough this piece was loose spinning around causing all the damn noise... So I just pulled it off for now...
So is this piece important?
Oh, also isnt this the peice ppl remove all the time for B series swaps to make the axles fit correctly?
Old Dec 30, 2006 | 11:13 AM
Tetanus's Avatar
Default Re: How important is this peice? (Exempt)
Not really... I am sure you will get some people on here that will argue that it is important, but all it is is a dust shield like you said. I'm pretty sure I have read a B sereis swap guide into 88-91 EF chassis where it told you to remove them before you install the axles, and I know I did when I put my B16A in my CRX.
xDicktonesx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exempt &raquo;</TD></TR><TR><TD CLASS="quote">Number 2 in the pic:
Oh, also isnt this the peice ppl remove all the time for B series swaps to make the axles fit correctly?</TD></TR></TABLE>
yes, and if you dont your axle wont last 50 feet.
Old Dec 30, 2006 | 11:22 AM
Exempt's Avatar
Sweet... Thanks for the replies guys!
So ppl run them like this all the time without reliability problems? (wheel bearing failure is my main concern)
Old Dec 30, 2006 | 11:26 AM
Default Re: (Exempt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exempt &raquo;</TD></TR><TR><TD CLASS="quote">Sweet... Thanks for the replies guys!
So ppl run them like this all the time without reliability problems? (wheel bearing failure is my main concern)</TD></TR></TABLE>
mine work flawlessly.
dr_latino999's Avatar
Well my thinking is that it is a spacer of some sort for the whole axle, hence why you have to remove it? Why is it really there?
Old Dec 30, 2006 | 12:49 PM
EK FLY's Avatar
Default Re: (dr_latino999)
if u remove that pice # 2 , ur bearing will be loosen for thats what happen to my hatch if i remove that pice my wheel will move around but if I install it straight
Old Dec 30, 2006 | 01:08 PM
ChickenH's Avatar
Default Re: How important is this peice? (Braddy)
Im pretty sure its the dust seal for the inner of the sealed wheel bearing. it is on the d series axles. you have to remove it to put a b series in. I dont think it is needed on a d series it might just make your wheel bearings last longer driving thru mud.
Old Dec 30, 2006 | 01:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Well my thinking is that it is a spacer of some sort for the whole axle, hence why you have to remove it? Why is it really there?</TD></TR></TABLE>
no it really is a dust deal. its rubber on metal. but with a b-series that rubber will catch the inside of your hub and snap the CV joint every sing time.
trust me, one day i broke 3 axles, i just about gave up, then i took one look at the piece, pulled it off with a pair of pliers and i have has smooth axles ever since. i learned the hard way so the rest of you dont need to make the same stupid mistake
Old Dec 30, 2006 | 01:21 PM
Default Re: (xDEFTONESx)
So the B-Series axle hub has a larger O.D. and that's why the dust ring snags?
Old Dec 30, 2006 | 01:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">So the B-Series axle hub has a larger O.D. and that's why the dust ring snags?</TD></TR></TABLE>
the probably did on the integras, which is what everyone buys the axles for, then puts them on their EF.
Old Dec 30, 2006 | 01:39 PM
Gotcha! Finally learned the reasoning behind the whole dust ring removal
Old Dec 30, 2006 | 01:57 PM
shortyz21's Avatar
Default Re: (super-hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch &raquo;</TD></TR><TR><TD CLASS="quote">if u remove that pice # 2 , ur bearing will be loosen for thats what happen to my hatch if i remove that pice my wheel will move around but if I install it straight </TD></TR></TABLE>
what the expletive did you just say?
batto24GSR
Sep 7, 2012 09:42 AM
Shorty C
May 15, 2004 06:10 AM
Sketch_hs
25
Jul 27, 2003 02:06 PM
SprayinCX
23
Jul 19, 2003 06:48 PM
