question sohc vtec
Old Dec 30, 2006 | 11:07 AM
89nonvtec's Avatar
Default question sohc vtec
4 get this change my mind
Modified by 89nonvtec at 1:01 PM 1/1/2007
Old Dec 30, 2006 | 11:21 AM
Exempt's Avatar
Yes you can swap that head on your block... Its called a "Mini-me"... Heres a write up for it...
https://honda-tech.com/zerothread?id=554053
I personally wouldnt reccomend just running a push switch tho, or even just an RPM switch (where at a certain RPM it activates VTEC for you) because they wont add the proper fuel or adjust the ignition timing accordingly like a true VTEC ECU would...
Old Dec 30, 2006 | 11:34 AM
SIred91's Avatar
Rainman
Default Re: (Exempt)
Get the ECU that matches the head, do it right.
Then find someone to do the wiring harness for you, or go to Rywire.
Old Dec 30, 2006 | 11:51 AM
89nonvtec's Avatar
Default Re: (SIred91)
thanks that helped alot
Old Dec 30, 2006 | 01:17 PM
ChickenH's Avatar
Default Re: question sohc vtec (89nonvtec)
I have done it with a MSD rpm activated switch before. but the computer makes The whole ignition and timing map change in Vtec. so to make the car run like it is supposed to you should get a NEW ECU. you only have to add something like 5 wires to use the right ECU. ( depending on if you are also swaping from DPFI to MFI at teh same time).
iv'e got one of these heads and intake and dist and ecu laying around that im going to do soon for my roomates car. I put 11.5 to one pistons in his Dpfi d15 and an adjustable cam pully already. is a MINI ME worthwile swap?
supergoob
Mar 14, 2008 04:52 AM
civicjoe
16
Feb 25, 2008 01:57 PM
HatchEh2
10
Jun 3, 2006 09:37 AM
prjctCIVIC
29
Mar 20, 2003 09:38 PM
2000_Civic_Si
Sep 10, 2002 09:28 AM
