cel wont come on when I turn on the ignition and pump wont prime but car will start fine
Old Dec 30, 2006 | 06:54 AM
tanzoid's Avatar
Default cel wont come on when I turn on the ignition and pump wont prime but car will start fine
I have a 92 VTI EG6 with an p30 edm ecu (it has been chipped).
The probelm is that when I turn on the ignition the CEL does not come on and the pump does not prime, also when I put the car in self diag. mode the cel light stays on. But the car runs fine and it will start, abiet a few seconds slower as the pump has not primed the system.
I have done a lot of searches on the forums and have done quite a few checks this is what I have done so far:-
The CEL light works fine when I ground the connection from the ecu.
Checked all the 12 v suppiles to the ECU,
Checked all the earths to the ecu (cleaned thermostat housing earths),
Checked ecu circuit board solder joints,
Bench tested main relay (good) and checked the wiring from the relay to the ecu, pump etc.
Changed a few of the electrolitic capacitors on the ECU (c14 (fuel pump one), c15 and a couple others.
I have found no defects.
Does anyone know which components on the ECU are involved in priming the pump for a few seconds on ignition and which components drive the CEL on self test.
Thanks for any help.
Old Dec 30, 2006 | 08:15 AM
b16a2civicesi's Avatar
Default Re: cel wont come on when I turn on the ignition and pump wont prime but car will start fine (tanzoi
id try another ecu to see if that fixes it so you know if its the ecu or not
Old Dec 30, 2006 | 12:49 PM
tanzoid's Avatar
If I had a spare ECU, I would try it.
I am pretty sure the probelm in the ecu anyway.
Old Jan 4, 2007 | 03:50 AM
tanzoid's Avatar
Bump
Bushybob94
Jun 5, 2018 11:40 AM
Rawnee7
Jun 21, 2014 08:28 PM
gitchesum
Feb 28, 2009 05:39 PM
blackeg
Apr 3, 2007 07:07 AM
boosted k20
Apr 14, 2005 01:17 PM
