15x7.5 tire size question
Old Dec 30, 2006 | 03:18 AM
EFresh's Avatar
Default 15x7.5 tire size question
i just got a set of drag's dr20. i was wondering wat tire size would be good for it. i have a set of 195/55/15's but wasnt sure if its good for these wheels or would the 195's work? i was thinking for selling them and getting 205's. thanks in advance
Old Dec 30, 2006 | 03:31 AM
vtecsi00's Avatar
Default Re: 15x7.5 tire size question (EFresh)
205/50r15 would be better
Old Dec 30, 2006 | 03:34 AM
EFresh's Avatar
Default Re: 15x7.5 tire size question (vtecsi00)
with the 195's, would the lip of the rim stick out much. if its not that bad, i wouldnt mind slapping the 195's on. dont wanna go through the hassle selling the tires and getting new ones. performance wise im not to worried about. just dont want the lip to stick out badly.
Old Dec 30, 2006 | 04:24 AM
old man neri's Avatar
What car is this for and what is the width of those rims?
Old Dec 30, 2006 | 06:42 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 15x7.5 tire size question (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">What car is this for</TD></TR></TABLE>
Good question. Remember, you need to get the proper tire size for the CAR, not just for the wheel.
If your car is a CRX, del sol, or pre-'96 Civic, then the proper 15" tire size is 195/50-15. If your car is an Integra or '97-00 Civic, then it's 195/55-15 or 205/50-15. In either case, assuming you're talking about tires for street use, and not just for the track or autocross or dragstrip, 15x7.5 is TOO WIDE for your car.
If you have an Accord or Prelude, then 15x7.5 might work.
So what kind of car is this for? Model, version, body style, engine...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">what is the width of those rims?</TD></TR></TABLE>
15x7.5, according to the topic title...
Old Dec 30, 2006 | 10:54 AM
EFresh's Avatar
Default Re: 15x7.5 tire size question (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">
its for a 90 si crx. yea i knew they are pretty wide for the car. my plans were just to roll the fenders and push it out a tad bit.
Old Dec 30, 2006 | 12:42 PM
vtecsi00's Avatar
195/50r15 is what you need for your application
Old Dec 30, 2006 | 01:29 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">195/50r15 is what you need for your application</TD></TR></TABLE>
And 195/50-15 is only approved for rims 5.5-7.0 inches wide.
Old Dec 30, 2006 | 07:19 PM
EFresh's Avatar
i ended up just installing the 195/55/15's. so far i havent rubbed yet, did a couple of U turns but carefully, no rub. heres a picture
Old Dec 30, 2006 | 11:58 PM
Careful on the highway, your speedo will under read.
Old Dec 31, 2006 | 12:34 PM
EFresh's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">Careful on the highway, your speedo will under read.</TD></TR></TABLE>
hmm i didnt know of this... like how much of an under read would i get?
Old Jan 1, 2007 | 04:47 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFresh &raquo;</TD></TR><TR><TD CLASS="quote">hmm i didnt know of this... like how much of an under read would i get?</TD></TR></TABLE>
About 3.5 percent. Which may not sound all that much, but it means that the tires are MUCH bigger than stock.
That's why 195/50-15 is better for your car - no error at all.
Old Jan 2, 2007 | 12:58 PM
efvader's Avatar
i think the 195/50's on the 7.5 would have been good
i know its not the "proper" size but you would be fine..
i have friends that run 195's on 8" wide wheels with no problems
Old Jan 2, 2007 | 01:01 PM
Default Re: 15x7.5 tire size question (efvader)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efvader &raquo;</TD></TR><TR><TD CLASS="quote">
i have friends that run 195's on 8" wide wheels with no problems </TD></TR></TABLE>
Let me guess........they drive VWs?
If a manufacturer of a tire says that the tire they just made should only be put on a certain width of rim it's usually best to follow their recommendation, they made it for a reason.
Old Jan 2, 2007 | 04:29 PM
vtecsi00's Avatar
i agree with you there old man neri but tell tha to team falken that run's that size on a 8 wide wheel on there toyota for drifting
Old Jan 2, 2007 | 05:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">i agree with you there old man neri but tell tha to team falken that run's that size on a 8 wide wheel on there toyota for drifting</TD></TR></TABLE>
Ya, but there is also a difference between doing it on a closed track under controlled conditions and doing it on the highway. On the track if something goes wrong you have a helmet, roll cage, room around you, and professional rescue teams already there. On the highway, well, just trouble awaits.
Old Jan 2, 2007 | 05:46 PM
vtecsi00's Avatar
not when you are running 70psi in your tires
Old Jan 3, 2007 | 03:59 AM
efvader's Avatar
i know what your sayin.
and am sure everyone one here follows the guidelines of a company 100% when using it
Modified by efvader at 1:24 PM 1/3/2007
Old Jan 3, 2007 | 05:41 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efvader &raquo;</TD></TR><TR><TD CLASS="quote">i know what your sayin.
yup, not even one of these cars on here are lowered or has different engines or anything that the manufacture does not explicitly say is OK to do. this is not sarcasm.
Old Jan 3, 2007 | 07:30 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 15x7.5 tire size question (Bailhatch)
The range of approved rim widths is for safety. It's also for what size rims won't be impossible for mounting the tires onto.
But hey, do whatever you want. If you think your tire guy can mount them. And if you know what you'll then do if he can't.
Old Jan 3, 2007 | 10:42 PM
vtecsi00's Avatar
they can be mounted pretty easily with a cheetah blaster and a euro machine...a pain in the *** sometimes...not my look but hey what ever makes you happy is all that matters
Old Jan 4, 2007 | 12:07 AM
No2Pencil's Avatar
what suspension are you running?
mykulangot92
Dec 16, 2010 04:35 PM
Scottyk6
Feb 14, 2008 07:17 AM
cor0780
Oct 15, 2007 07:01 PM
slow99dx
Oct 13, 2005 01:18 PM
jbell
Apr 23, 2004 05:42 PM
