2000 Si exhaust/header question
Old Dec 29, 2006 | 10:24 PM
S2k Hybrid's Avatar
Default 2000 Si exhaust/header question
I have a 2000 Si soon to have a b20z in it. I wanted to know which header I can use to bolt up to an oem/aftermarket Si exhaust. I was trying to avoid welding but if I have no choice, ehh what can I do?
Old Dec 29, 2006 | 10:26 PM
Syndacate's Avatar
Default Re: 2000 Si exhaust/header question (S2k Hybrid)
I believe you can use any B series exhaust manifold / header.
Old Dec 29, 2006 | 10:29 PM
S2k Hybrid's Avatar
Default Re: 2000 Si exhaust/header question (Syndacate)
but arent the lengths different?
Old Dec 30, 2006 | 07:01 AM
S2k Hybrid's Avatar
yes no?
Old Dec 30, 2006 | 07:14 AM
pdiggitydogg's Avatar
They are
The b16 has a shorter deck height too, so you cant use your oem header on a b20, because it wont clear the pan.
Get an oem LS header, if you want it to be cheap
Old Dec 30, 2006 | 07:20 AM
Sloshy's Avatar
up to the header with no modification get the same model header you have now, mostly yo have the si header so if your ordering order for a 99-00 si header and you wont have weld it should just bolt up...
and yes all b-series bolt up to a b-series head, but are different lengths at the bottom..
my SI header is shorter at the bottom then my gsr header
Old Dec 30, 2006 | 07:40 AM
S2k Hybrid's Avatar
Default Re: (pdiggitydogg)
So b16 header is a no no. Any other b series is good? A friend of mine was looking to sell me his gsr header but I wasnt sure about the length
Old Dec 30, 2006 | 08:21 AM
imacoolkid's Avatar
Default Re: (S2k Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S2k Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">So b16 header is a no no. Any other b series is good? A friend of mine was looking to sell me his gsr header but I wasnt sure about the length </TD></TR></TABLE>
well just my 2 cents but here ya go. i had my old header from my b16 motor and tried to install onto gsr motor, but would not clear oil pan because of the deck height difference. almost a half inch diff on b16 and b18 block. and also as stated above the collector lengths are different for each model. i do know an itr header will fit a gsr motor in civic with no mods hope that helps a lil
Old Jan 3, 2007 | 12:35 PM
S2k Hybrid's Avatar
Default Re: (cmillertime05)
Ok so the ITR header will clear on the gsr but what about the b20? I found a usdm itr header for real cheap and im thinking of buying it. Also I failed to mention this before, I have the top portion of the header from the b20, is the bottom portion different on b-series models or the top half?
dougdog084
Sep 9, 2010 08:51 PM
hatchet_honda
Apr 1, 2009 12:12 AM
whitemike1644
Jun 10, 2003 07:36 PM
BerlinaAP2
Apr 1, 2003 09:55 PM
