Very weird headlight problem
Old Dec 29, 2006 | 07:23 PM
carboncivic's Avatar
Default Very weird headlight problem
Ok, this is strange. My headlights were working fine one minute, and the next they just shut off. I figured, ok, must be a fuse, since they went out at the same time. Checked fuses under the dash and hood, and all were good. Now the strange thing is, my high beams still work, but the low beams dont. All the dash lights light up when i turn them on, but the low beams dont light up, only the highs do. Any idea what this could be?
Old Dec 29, 2006 | 08:06 PM
o_fatmike_o's Avatar
Default Re: Very weird headlight problem (carboncivic)
change ur bulbss. if that doesn't work its either ur switch(on ur sterring column) or a short if its a short u have to fallow the wires from the lights to the switch to the battery good luck!
Old Dec 29, 2006 | 09:35 PM
D16Clunkin's Avatar
Default Re: Very weird headlight problem (o_fatmike_o)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o_fatmike_o &raquo;</TD></TR><TR><TD CLASS="quote">change ur bulbss. if that doesn't work its either ur switch(on ur sterring column) or a short if its a short u have to fallow the wires from the lights to the switch to the battery good luck! </TD></TR></TABLE>
nah it couldint be the bulbs if they went out at the same time.....prolly your wires
jaymus1981
Jul 21, 2014 08:30 PM
Deafkid2005
Apr 22, 2014 07:51 AM
xJDMB16x
Oct 11, 2009 11:06 PM
808EK4
Oct 27, 2007 03:30 AM
sillvercivicgsr
Jan 12, 2004 02:43 PM
