b20 with b15 head.. i just blew the head i beliew please help.
Old Dec 29, 2006 | 06:59 PM
Kirk@SyndromeAuto's Avatar
Default b20 with b16 head.. i just blew the head i beliew please help.
b16*
hows it going guys. so i did a b20 vtec a few weaks ago and sound like it ran strong. so bunch of my friends and I did a ortega run and on the way back i heard a clacking somewhere in the engine and i cant figure out were its coming from
on the side of the road we took my valve cover off to see if we could see anything but nothing un normal. so we started it back up and i got it home. it doesnt rev right its idling to 2 then drops to .5 then back up and down. the weird thing is i can feel massive vibrations from my clutch. but thats probably cause im trying to change gears when its revving al funny. also another thing is when i let of the gas when driving it feels like you hit a brick wall and it dies really fast. so i dono if its the clutch or the head.
my tranny was perfectly fine before and also i just put a brand new clutch in.
any suggestions or ideas to what it could be?
thanks
Old Dec 29, 2006 | 08:24 PM
igotthaspirit's Avatar
Default Re: b20 with b16 head.. i just blew the head i beliew please help. (Kirk@SyndromeAuto)
sounds like you got bigger problems than a clutch or head.
Old Dec 29, 2006 | 10:45 PM
DC2 Mang's Avatar
is the car smoking at all?
sounds like you could have cashed out the bottom end, b20 sleeves and rod bolts are not meant to be past 7k for extended periods of time
Old Dec 30, 2006 | 02:22 AM
saikouEF8's Avatar
if u let off the gas and it sounds like the car wants to hurl/spill its guts out id say spun bearings...
Old Dec 30, 2006 | 12:22 PM
doood's Avatar
been there done that
did you just slap the head on the block? or did you do a rebuild first? how high were you revving?
Old Jan 2, 2007 | 12:33 AM
Default Re: b20 with b16 head.. i just blew the head i beliew please help. (doood)
slapped it on without rebuild. password jdm said that there b20 long blocks are compression tested and ****. so i trusted that. my b16 head came off my old ls vtec which smoked like a mother.
car doesnt smoke at all really.
Old Jan 2, 2007 | 12:34 AM
oh ya i took off the head and nothing looks to fucked up i dono if it is the head. if its the bottom end that sucks ***. im so tired of taking **** out of my car and fixing it
any specific way to see if its a rod bearing without taking the whole bottom end appart..
Old Jan 2, 2007 | 01:30 AM
CompanyFlow's Avatar
Lets all believe what someone whose trying to sell something says without question.
Old Jan 2, 2007 | 05:49 AM
1badteg's Avatar
dude you should have invested a little more time and money into your b20/vtec. so sad...but it happens. id put 50 bucks on a spun bearing. did you get rev happy? did you upgrade your water pump or oil pump? a good build will cost you 2000 at least. but some for less. by the way the only way to see if you have a spun bearing would be to go thru the oil pan. look for discolored rods. good sign of a spun bearing. should be easy to fix but you'll need a new crank unless you want it to happen again. get the new one micropolised and have installed professionally if you dont feel comfortable doin it.
Modified by 1badteg at 7:14 AM 1/2/2007
Old Jan 2, 2007 | 12:04 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kirk@SyndromeAuto &raquo;</TD></TR><TR><TD CLASS="quote">slapped it on without rebuild. password jdm said that there b20 long blocks are compression tested and ****. so i trusted that. my b16 head came off my old ls vtec which smoked like a mother.
car doesnt smoke at all really.</TD></TR></TABLE>
how high were you revving? if you were going over the b20's stock rev limit for extended periods of time without doing anything to the bottom end, you just screwed yourself.
Old Jan 2, 2007 | 03:29 PM
Fat Chick Magnet's Avatar
was block balanced? because b20 isnt meant to rev past 7000 rpm if you were reving past 8000 that could be your problem.
Old Jan 2, 2007 | 04:06 PM
Default Re: (dc2rtek)
well must be a spun bearing... cause heads fine
i have my old ls vtec block which im jsut going to put new rings on and slap it back together or i have to choice of a b16a2 bottom end which one should i slap back on.
the b16a2 is stock.
the ls block is sleeved and has type rarh pistons and i dono what else but it just needs rings. thats what was in my car before.
hybrid_vtec
20
Apr 21, 2010 10:22 AM
gearhead818
Mar 21, 2010 07:48 PM
804tuned
Engine Management and Tuning
Jul 21, 2009 12:11 PM
shroomyman
Jun 6, 2002 09:20 AM
