VSS Problem
I have 92 Civic VX with a OBDI LS swap and a JDM SiR gauge cluster. For some reason, even though I've replaced the VSS twice the speedo still refuses to work. I was wondering if any of you had a similar problem to this. Any help would be appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by malubawla »</TD></TR><TR><TD CLASS="quote">also try to replace the vss connector.....had a similar issue</TD></TR></TABLE>
Same here.
I've also seen a few failed gauge clusters
Same here.
