dc 4-1 or jdm itr 4-1
Old Dec 29, 2006 | 05:23 PM
Fat Chick Magnet's Avatar
Default dc 4-1 or jdm itr 4-1
Getting rid of my jdm 4-2-1 "jasma" header and im looking to either get DC 4-1 header or JDM ITR 4-1 header. Which one you think i will get more power?
have anyone of you had experience with both of them?
Old Dec 29, 2006 | 05:29 PM
jdm_bones's Avatar
Default Re: dc 4-1 or jdm itr 4-1 (dc2rtek)
I've had both the DC4-1 header and the jdm 4-1 header..they felt pretty much the same...never dyno'd it, to see for sure, but I'd go with the jdm 4-1, just because you can put a heat shield over it, this way cops don't hassel you!
Old Dec 29, 2006 | 05:34 PM
doood's Avatar
been there done that
if im not mistaken dc's jdm 4-1 is a copy of the jdm itr 4-1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">I've had both the DC4-1 header and the jdm 4-1 header..they felt pretty much the same...never dyno'd it, to see for sure, but I'd go with the jdm 4-1, just because you can put a heat shield over it, this way cops don't hassel you! </TD></TR></TABLE>
x2
Old Dec 29, 2006 | 05:36 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: dc 4-1 or jdm itr 4-1 (doood)
doood you are correct
Old Dec 29, 2006 | 06:08 PM
good ****. can i use stock gsr front heat sheild or do i need to buy jdm itr heat sheild?
Old Dec 29, 2006 | 06:21 PM
silentdeath12886's Avatar
i believe you need to get the jdm itr heat shield. and id choose jdm itr over dc sports cause jdm itr is oem
Old Dec 29, 2006 | 07:14 PM
Boots's Avatar
Default Re: (silentdeath12886)
i kept the stock header on my itr...i just took the heat shield off and header wrapped it...ive researched it an apparently honda made that bitch pretty right stock
Old Dec 29, 2006 | 07:29 PM
DC2 Mang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdeath12886 &raquo;</TD></TR><TR><TD CLASS="quote">i believe you need to get the jdm itr heat shield. and id choose jdm itr over dc sports cause jdm itr is oem</TD></TR></TABLE>
you do need to buy the jdm itr heatshield for it
another plus to using the OEM header is that you can run a fastline skid plate on the bottom to potentially prevent some dents
Old Dec 29, 2006 | 08:56 PM
Kangolbrand's Avatar
what if its aready dented? suggestion... since mine got a fat dent.. half the tube dented in
Old Dec 29, 2006 | 09:01 PM
DC2 Mang's Avatar
Default Re: (Kangolbrand)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kangolbrand &raquo;</TD></TR><TR><TD CLASS="quote">what if its aready dented? suggestion... since mine got a fat dent.. half the tube dented in</TD></TR></TABLE>
take it to a motor cycle shop, they can usually take dents out of headers
Old Dec 29, 2006 | 10:28 PM
how much would they charge you think?
Old Dec 29, 2006 | 11:25 PM
r3v da t3g's Avatar
If im not mistaken its really hard to not dent those damn jdm itr headers. . . . dont they sit like way lower then usdm
Old Dec 30, 2006 | 12:35 AM
Vtecfool's Avatar
Default Re: (r3v da t3g)
how about dc jdm 4-1?
Old Dec 30, 2006 | 10:34 AM
black92DA's Avatar
Default Re: (Vtecfool)
i have some jdm itr headers w/ heat shield if ur interested
Old Dec 30, 2006 | 10:39 AM
teknoracing's Avatar
Default Re: (black92DA)
JDM FTW
Old Dec 30, 2006 | 11:58 AM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtecfool &raquo;</TD></TR><TR><TD CLASS="quote">how about dc jdm 4-1?</TD></TR></TABLE>
ground clearence sucks with that one too
Old Dec 30, 2006 | 12:20 PM
1nicegsr's Avatar
Default Re: (doood)
the jdm on has a 2.5in collecter on it. dc makes 2 differ headers, one is 2in (whitch will bolt up perfect to the stock cat flange), the other is 2.5in. if you get the jdm, you have to change the flange on the cat or test pipe... whatever your using. passwordjdm.com has the 2.5 flanges. hope this helps
Insane Si Lum
Jan 20, 2004 04:58 PM
01nhbgsr
Jun 26, 2003 06:32 PM
Norcalstoppy
Oct 22, 2002 08:06 PM
JDMvtecDRAGSTA
Mar 29, 2002 12:12 PM
