How to remove Rear engine mount?
Old Dec 29, 2006 | 04:52 PM
Sweetsystem's Avatar
Default How to remove Rear engine mount?
Guys I need some detailed info on how to remove the rear engine mount. I searched and everyone is vague. Do I have to remove my intake Manifold? Power steering rack?
Ultimately im trying to remove the engine. got everything else off except the mounts and intake mani.
Thanks
Old Dec 29, 2006 | 04:56 PM
Fat Chick Magnet's Avatar
good luck. its a bitch to take it out.......took 3 guys to take my rear mount out and replace it with innovative. one guy jacking the motor up another guy watching from the top removing the bolt and another guy under the car trying to pull the mount out.
oh and it was our first time.
Old Dec 29, 2006 | 05:15 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (dc2rtek)
removing the intake maifold is the easiest way to go about it, then the mounting bracket for the motor mount, then the mount itself
here's a good write up on it: http://www.team-integra.net/fo...age=2
Old Dec 29, 2006 | 05:16 PM
i just took my intake off and it was easy to get to it.
Old Dec 29, 2006 | 05:25 PM
jdm_bones's Avatar
Default Re: How to remove Rear engine mount? (Sweetsystem)
Put your car on jack stands, come from under the car and hit with an impact gun. Make sure that you have a jack at the tranny ever so slightly pushing up on it and make sure that the crane is well attached to the engine...
Old Dec 30, 2006 | 03:16 AM
dc4teggiehatch's Avatar
took off tranny mount and left torque mount, loosend rear moutn bracket as well, jack stands on car and jack under motor, slowly raised/dropped til had enuff room (play) to wiggle out the rear mount. the hardest part is putting the bolts back in tight. you need alot of tools.
Old Dec 30, 2006 | 05:57 AM
qfast817's Avatar
Default Re: (96teggiehatch)
its easyer when you remove the breather box, take out the rear l bracket
Old Dec 30, 2006 | 08:25 AM
PrinceAli132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggiehatch &raquo;</TD></TR><TR><TD CLASS="quote">took off tranny mount and left torque mount, loosend rear moutn bracket as well, jack stands on car and jack under motor, slowly raised/dropped til had enuff room (play) to wiggle out the rear mount. the hardest part is putting the bolts back in tight. you need alot of tools.</TD></TR></TABLE>
x2
Ali
Old Jan 2, 2007 | 12:13 PM
Thanks Guys. Completed all Maint. T Belt, Clutch, Tranny Fluid, Axles, front torque mounts, polyurethane engine mount inserts, All belts and hoses, Valve cover gasket, and Cam plug. Runs like brand new!
Side note: The Urethane inserts really firm up the engine, almost too much for my comfort level. I might be taking the two front ones out and just keeping the rear one in.
98bucket
Mar 1, 2011 08:41 AM
acmoc
Nov 25, 2008 10:03 AM
the.hamburglar
Jul 21, 2005 02:47 PM
SurferX
Mar 3, 2003 02:16 PM
