b16 turbo
Old Dec 29, 2006 | 04:17 PM
gjc5500's Avatar
Default b16 turbo
next week im gonna help my firend install a turbo into his integra. i was wondering if anyone could help me by giving me pics of the oil lines. i know the return goes to the pan. i needs to know hwere to get the oil from, and can a turbo be used w/ the A/C installed
Old Dec 29, 2006 | 04:38 PM
DC2 Mang's Avatar
Default Re: b16 turbo (gjc5500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gjc5500 &raquo;</TD></TR><TR><TD CLASS="quote">next week im gonna help my firend install a turbo into his integra. i was wondering if anyone could help me by giving me pics of the oil lines. i know the return goes to the pan. i needs to know hwere to get the oil from, and can a turbo be used w/ the A/C installed</TD></TR></TABLE>
you can use a T-fitting off of the oil pressure sensor on the back of the block for the oil feed line
it depends on what size turbo and the type of turbo manifold you are going to be using, I would test fit to see if they are going to be A/C and PS compatable
Old Dec 29, 2006 | 04:50 PM
gjc5500's Avatar
Default Re: b16 turbo (DC Mang)
do you have a pic of the location of the pressure sending unit's hole for the oil. the manifold looks like this
and its a t3 turbo out of a 85 300zxt
Old Dec 29, 2006 | 04:54 PM
DC2 Mang's Avatar
Originally Posted by stealthmode62
Here's a little write up I did with some pictures to give you the idea.
The source of oil for your turbo is the starting point of creating your oil line kit. Most vehicles use the factory oil pressure sensor as a starting point, while some cars use other areas such as the head or directly off the oil pump. Our kit can be made for any source, though the majority of our customers use the factory oil pressure sensor.
Our custom block fitting uses this sensor port to pull the oil source while retaining the factory oil pressure sensor function. Virtually all oil pressure sensors are a rare 1/8 bspt, and are a very difficult thread size to find. Our block fitting has the correct 1/8 bspt male threads for the oil pressure sensor port, and a 1/8 bspt female port on the back to retain the factory oil pressure sensor. Off the sides of the block fitting are two 1/8 npt female ports to create the oil source. When only using one port the other is plugged with a 1/8 npt plug. Here's a picture of the block fitting:
Installed into the oil pressure sensor port:
Once you have determined where your oil source will be, then you will need figure out how you would like to route your oil feed line, and measure how long it will need to be. Measure from the oil source to the turbo oil inlet. Our feedlines are 48" and are long enough for virtually all engine bay dimensions. If a longer line is needed, feel free to send us an email.
<FONT SIZE="16pt">Measureing the turbo</FONT>
There are two measurements of turbos that make the oil line kit interchangable. Here is how to determine the fittings you will need.
<FONT SIZE="13pt">Oil inlet thread size</FONT>- The oil inlet thread size is where the oil will enter your turbo. There are many different thread sizes, and some turbos aren't threaded at all. The easiest way to determine which thread size you have is to test fit differnt bolt thread sizes into the turbo until you find the correct one. Some standard sizes are 1/8 npt,
1/4 npt, 7/16 inverted flare, and an assortment of metric sizes usually a 10mm or 12mm with different thread pitches.
<FONT SIZE="13pt">Oil drain flange</FONT>- The other critical measurement in selecting which oil line kit will work for your turbo is the oil drain flange. By measuring the mounting bolt holes of your drain flange from center to center you can obtain this measurement. Standard drain flange measurements are 38mm, 44mm, and 50.8mm. In rare occurances there are other sized drain flanges. By ordering the next smallest size and opening up the mounting holes on the drain flange you can mount a drain flange on any turbo.
The drain hose is what will carry the oil out of the turbo and back into the oil pan. Depending on how far your manifold sets your turbo from the oil pan, you may need a different length of drain hose. Those with turbos further from the oil pan than 14 inches are encouraged to order our Universal Kit which has a 20 inch drain hose.
Installing the included barb fitting into the oil pan will allow the oil used to cool the turbo to be returned to the engine via the oil pan. There are many different fittings you can install. You can weld a 5/8 O.D. (Drain hose has 5/8 I.D.) length of pipe to the pan as well.
<FONT SIZE="13pt">How it's done</FONT>
Mount the turbo and manifold to get an idea of where it's going to sit. Either place or install the oil pan, and make a mark that will give you the best downward slope. It should be somewhere between the top and 1 1/2 inches down.
After you have it marked, make a pilot hole, and drill it out using a drill bit slightly smaller than the 3/8 threaded end of the barb fitting. Use your drill to slowly open the hole up until you can get the threads to "catch".
At this point your hole is where you need it to be to thread in your fitting. This is when I clean the pan completely with gasoline. Gas picks up all the metal shavings well. I slosh it around a couple times, a dump. I do this about 3 times and then wipe it down.
Start threading it in. Before the base of the barb fitting gets to the oil pan, you're going to want to use a sealer on the base of the pan around the hole. I use JB weld as well as alot of customers I hear from. RTV would probably work as well as others. Put the sealer around the hole. Tighten down the barb fitting until the base of it touches the pan. I don't torque it on there, but I tighten it. After it's tight, put another layer of sealer around the base of it.
courtesy of stealthmode performance
Old Dec 29, 2006 | 04:56 PM
gjc5500's Avatar
thx. thats exactly what i needed
Old Jan 1, 2007 | 02:04 PM
gjc5500's Avatar
alos, do i have to remove the A/C to install it?
Old Jan 1, 2007 | 02:06 PM
High0ctane's Avatar
I don't think so, I'd be more worried about the P/S pump. It should fit though, I had tried out a log style manifold like your on my friends Teg, but it was a bit more compact than yours. It had some clearance left...maybe you'll need slim fans.
boost4s2k
Honda S2000
Jul 9, 2009 02:21 PM
90hatchblack
Mar 1, 2007 07:57 PM
delsoldrew
Sep 4, 2006 12:56 PM
julian_gq
May 24, 2005 04:51 AM
rideblitz
14
Oct 27, 2004 01:09 PM
