How to tell the difference between Tial W/G 35 & 38
Old Dec 29, 2006 | 03:18 PM
Drkaccrd's Avatar
Default How to tell the difference between Tial W/G 35 & 38
Ok before you flame me this is an honest question. I have this tial with a 7psi wastegate spring. With the newer versions they discontinued the 35mm, I guess the slightly pointier looking one. Is the one I have a 38mm because of the flatter looking top?
Modified by Drkaccrd at 7:31 PM 12/29/2006
Old Dec 29, 2006 | 03:36 PM
SlowReaction's Avatar
Default Re: How to tell the difference between Tial W/G 35 & 38 (Drkaccrd)
You have a 38mm
Old Dec 29, 2006 | 03:44 PM
Drkaccrd's Avatar
Default Re: How to tell the difference between Tial W/G 35 & 38 (SlowReaction)
cool, thanks for the response
Old Dec 29, 2006 | 04:03 PM
Soccerking3000's Avatar
yea you have a 38mm but why didnt you just measure it lol
Old Dec 29, 2006 | 10:08 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: How to tell the difference between Tial W/G 35 & 38 (Soccerking3000)
some of the newer 35mm's come with that top as well..
only 2 ways to be 100% sure
measure the inlet
email tial with the serial number
Old Dec 30, 2006 | 07:43 AM
Drkaccrd's Avatar
Default Re: How to tell the difference between Tial W/G 35 & 38 (wantboost)
Ill email the serial number to tial. Its already bolted up, to lazy to remove it and measure.
Old Dec 30, 2006 | 08:01 AM
booscivic's Avatar
if u have a 38mm and u say its 7psi it would boost a bit higher with the 35mm so just go for a run and see were the boost guages go!
35mm TiAL / spring discription
.3 bar / 4.35psi / small yellow
.45 bar / 6.53psi / small red
.65 bar / 9.43psi / small green
.8 bar / 11.6psi / small blue
38mm TiAL
.25 / 3.63psi / small yellow
.4 / 5.80psi / small red
.5 / 7.25psi / small green
.6 / 8.70psi / small blue
.7 / 10.15psi / big yellow
.8 bar / 11.60psi / big red
.9 bar / 13.05psi / big green
1.0 bar /14.50psi / big blue
Old Dec 30, 2006 | 08:14 AM
Drkaccrd's Avatar
Default Re: (booscivic)
We tried to get it tuned at 17psi but it wouldnt really hold it the boost would kinda drop. Ive defintely seen it hit 16psi. The reason why I asked is because I bought the large green spring so it can hold the boost. I havnt installed the spring yet. Any advice on that?
Old Dec 30, 2006 | 08:23 AM
booscivic's Avatar
just test with w/g no boost controller, also what kind of boost controller are u using?
Old Dec 30, 2006 | 08:45 AM
Drkaccrd's Avatar
Its a manual boost controller. Halmans boost controller. I'll try disconnecting it and see what happens. I thought I ordered the 7psi spring with it. I can only double the wastegate spring psi if Im not mistaken right?
Old Dec 30, 2006 | 09:26 AM
booscivic's Avatar
depends on which big spring u got? which ever big spring u got and the small spring just add the both and youll get whatever psi
Old Dec 30, 2006 | 09:48 AM
Drkaccrd's Avatar
good thing you said "add" to the small spring already inside of it. I would have just taken that one out and installed the big green one alone.
Old Dec 30, 2006 | 09:54 AM
booscivic's Avatar
if u have the small green on it right now and you add the big green it would yield almost 21psi thats assuming u have a 38mm.
Old Dec 30, 2006 | 10:20 AM
Drkaccrd's Avatar
Oh so if I take out the small green and put in just the big green itll be 13psi and change??
ndogg
Jun 27, 2009 12:16 PM
juanb
Nov 23, 2006 09:36 PM
civic_6991
Feb 23, 2004 10:35 AM
ebp 99 si
Jun 15, 2003 07:45 PM
