pls help.. bout idle!!
Old Dec 29, 2006 | 12:37 PM
smokerz212's Avatar
Default pls help.. bout idle!!
my idle plays in 700-900 and it feels like the engine will die... then after a while it will go up to 1500 steady and back to 900 when warmed up, it only happens when the car sits for a while... pls help us out. will this cause big problem in the future?
i look and try to clean the IACV but found out that the 2 hoses that connected there has no hose.. i mean they only cover it ... so do i still need to clean it? and my FITV also has no hoses and also blocked... my engine is b16a2 converted to obd1.. skunk2 chipped p28 ecu and generic intake...
Old Dec 29, 2006 | 12:45 PM
THC07's Avatar
Default Re: pls help.. bout idle!! (smokerz212)
https://honda-tech.com/zero...53955
that skunk 2 chip could be to blame. that **** is crap. unless you can rule that out... was it idling ok b4?
Old Dec 29, 2006 | 02:12 PM
smokerz212's Avatar
i got the car with this set-up... and yes it idle b4....
Old Dec 29, 2006 | 07:15 PM
smokerz212's Avatar
and whats the best chip to use in obd1 p28 ecu if i have b16a2?
Old Dec 29, 2006 | 07:23 PM
99sibluehatchwitb16's Avatar
change your oil
Old Dec 29, 2006 | 07:42 PM
thizzledance's Avatar
Default Re: (99sibluehatchwitb16)
tighten throtle body cables...clean engine bay and see what's going on in that beezie...
clean filter(may cause bogging, look 4 leakage, or anythin unusual
=+O)) ---off topic AHHH saddam is dead!!!
Old Dec 30, 2006 | 06:57 AM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokerz212 &raquo;</TD></TR><TR><TD CLASS="quote">and whats the best chip to use in obd1 p28 ecu if i have b16a2?</TD></TR></TABLE>
is it stock? I/H/E? if you have a few bolt-ons and are close to stock, then get a p30 program. Stock. fuel and ign changes ( to the extent of name brands) will not help. very very small changes will. that's why, if you really care get it tuned.
another option is to find a *bin that you trust and get someone to burn it. a good place to start looking is pgmfi.org wiki. you should be able to find a good base map. if your lucky you might be able to find someone that has the same setup as you but tuned
good luck
Old Dec 30, 2006 | 09:44 AM
smokerz212's Avatar
yea.. i got intake and plan to put header and exhaust... after that ill try to use jdmp30 or rechipped my skunk2 p28... maybe the vision chipped.. and ill let jdmshit do the job.
Old Jan 9, 2007 | 03:46 PM
smokerz212's Avatar
ok i got it fixed for 2 days now... i just reset the ecu
keep_up
Jul 1, 2009 01:52 PM
89_crx
Apr 18, 2005 06:26 PM
AMG
Sep 30, 2003 12:14 PM
AMG
Sep 30, 2003 08:50 AM
