Will DOHC ZC pistons fit in a b16a?
Old Dec 29, 2006 | 11:10 AM
solerizr's Avatar
Default Will DOHC ZC pistons fit in a b16a?
Hypothetically, if you wanted to make a real high compression b16a motor, would the radically domed pistons of a DOHC ZC fit?
Old Dec 29, 2006 | 11:16 AM
kaiba's Avatar
Default Re: Will DOHC ZC pistons fit in a b16a? (solerizr)
Is it the difference between Dohc and Sohc ZC are the head. Basically isn't just a D16 non-vtec????
Old Dec 29, 2006 | 11:18 AM
jtchinoy's Avatar
i don't think so. if you're talking about the d16a6 (is this the right code?) from the 89 integra, it shouldn't. d series pistons are smaller than B series if I'm not mistaken. those pistons are for high compressioning sohc d series engines.
Old Dec 29, 2006 | 11:33 AM
solerizr's Avatar
Default Re: Will DOHC ZC pistons fit in a b16a? (jtchinoy)
Im thinking about the JDM ZC (pm7) pistons into a b16a2.
Old Dec 29, 2006 | 11:36 AM
Shaun_'s Avatar
If you are after oem pictons to up the compression get ctr's. I would just get some aftermarket pistons though.
Old Dec 29, 2006 | 11:38 AM
solerizr's Avatar
Default Re: (Shaun_)
It was just a theory thing: I figured it out, its not gonna happen; the b16 bore is 81mm, the ZC bore is 75mm.... so thers my answer to that.
Old Dec 29, 2006 | 11:40 AM
jtchinoy's Avatar
the ZC were of a b series? could've sworn they were fro ma D... news to me.
Old Dec 29, 2006 | 11:43 AM
solerizr's Avatar
Default Re: (jtchinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtchinoy &raquo;</TD></TR><TR><TD CLASS="quote">the ZC were of a b series? could've sworn they were fro ma D... news to me. </TD></TR></TABLE>
no the ZC is d.... I was just wondering if the bores happened to be the same since the motor designs are so similar.
Old Dec 29, 2006 | 12:14 PM
SkoundrelUSA's Avatar
cute little bastard
Pretty sure the DOHC ZC pistons are 75mm just like the other D-series so I'm gonna say no. I'm not 100% positive though
Old Jan 3, 2007 | 04:41 PM
joppe's Avatar
Correct. 75mm bore.
Bserieskiller
Jan 8, 2020 07:24 PM
axionm1k
Jul 11, 2008 02:07 AM
JDM_ZC
Apr 2, 2006 10:15 AM
Dc2 Joe
Mar 30, 2006 03:55 PM
Turbo Neon
Feb 3, 2004 09:18 AM
