zc and d series interchangeable parts?
would a d series piston fit into a zc?
ive got a set of srp pistons for a d series that i picked up and i watn to throw them in an old zc.. also are these pistons stock bore or overbore.. thanks..
Re: zc and d series interchangeable parts? (Turbo Neon)
The piston will fit and unless you are running crazy cams, you won't have an issue. The ZC has the biggest valves and they come in at a different angle. The only piston that I know of that takes this into consideration are the Endyn Rollerwaves.
Sonny
Re: (aka010010)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aka010010 »</TD></TR><TR><TD CLASS="quote">the zc is like a hybrid of a dohc and a sohc. best of both worlds.</TD></TR></TABLE>
Explain please this is intersesting
Screw you guys, I'm... going... home.
Which d-series and which ZC are you talking about? There are many different models of each so be specific!
