gsr gauges into 98ex?
Old Dec 29, 2006 | 09:10 AM
civic_hose'n's Avatar
Default gsr gauges into 98ex?
ok i heard from a local import shop that these gauge swaps were just plug and go? ok they plug up into my car but then they go crazy-like nothing works right,the turn signal makes the temp gauge go crazy and every thing is just not right. the car is a 98 civic with a b16a2 swap with the 2000 si ecu. what do i have to do to get these things working right>?
Old Dec 29, 2006 | 09:35 AM
carboncivic's Avatar
Default Re: gsr gauges into 98ex? (civic_hose'n)
check fuses? check ground?
Old Dec 29, 2006 | 10:09 AM
Default Re: gsr gauges into 98ex? (carboncivic)
dude be serious im not an idiot! i mean the gauges plug up but they are getting the wrong signals. im not a noob i know my honda stuff! i just need to know the wiring diagram for these gauges.
Old Dec 29, 2006 | 10:11 AM
gabebauman's Avatar
You have to re-pin the wires on the blue clips.
https://honda-tech.com/zerothread?id=474760
https://honda-tech.com/zerothread?id=1053318
http://www.geocities.com/_nitr....html
http://www.merritr.com/gauge.html
Old Dec 29, 2006 | 12:09 PM
GG99's Avatar
^ yup, its not plug n play at all
Old Dec 30, 2006 | 12:45 AM
BlueIntegraBoy's Avatar
It will physically plug in, but the wires are not in the same pins. Repinning is the key.
Old Dec 30, 2006 | 05:50 AM
adonis2oo2's Avatar
bust out the multimeter and start having some fun
Old Dec 30, 2006 | 07:17 AM
Syndacate's Avatar
Default Re: (adonis2oo2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adonis2oo2 &raquo;</TD></TR><TR><TD CLASS="quote">bust out the multimeter and start having some fun </TD></TR></TABLE>
naw, saftey pin and the pin-out diagrams. .
I don't think the 'teg clusters look good in the civics.
It's nice the way blue integra boy hooked it up w/ the mounts and all...but the bezel fit kinda kills it completely...and there's no way that bezel is gonna fit right, well at least not that I've seen. At least w/o a teg dash....though I'm sure some dude can customize the bezel enough - in which case it will look good .
Old Jan 1, 2007 | 06:27 PM
Default Re: (Syndacate)
well now that i know about the re-pinning of the harness is there anyone that has the wiring diagram and how to switch it out? like which wires go where?
thanks
Old Jan 1, 2007 | 06:35 PM
Default Re: (civic_hose'n)
Look at my post above
Old Jan 1, 2007 | 07:15 PM
Default Re: (BlueIntegraBoy)
thanks man alright i guess im ready to go get them gauges working, thanks
Old Jan 1, 2007 | 07:22 PM
civic nation's Avatar
you should just get a 99-00 si cluster it looks better and is plug and play.... my 2 cents
Old Jan 1, 2007 | 07:33 PM
gabebauman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_hose’n &raquo;</TD></TR><TR><TD CLASS="quote">well now that i know about the re-pinning of the harness is there anyone that has the wiring diagram and how to switch it out? like which wires go where?
thanks</TD></TR></TABLE>
I posted FOUR links earlier.
Old Jan 2, 2007 | 05:46 PM
Default Re: (gabebauman)
ok i got em in and working thanks for the help eveyone
Old Jan 2, 2007 | 10:16 PM
poorman's type-r's Avatar
* B A N N E D *
hey civic_hose'n i never knew SI came in 1998?
Old Jan 6, 2007 | 06:24 PM
Default Re: (poorman's type-r)
its a 98ex with the 2000si motor? with the 99 front end conversion
INCNTRL4
Mar 3, 2006 11:39 AM
Benjithx
Sep 8, 2004 08:59 PM
Benjithx
Sep 8, 2004 04:18 PM
