Jam nut wrench(valve adjustment)
Old May 13, 2002 | 01:38 PM
goforbroke's Avatar
MEAT PATTY
Default Jam nut wrench(valve adjustment)
I went to go and do my valve adjustment the other day. I have a b16a, do I really need the jam nut wrench from Snapon to do the adjustment. I tried to do it with a screwdriver and wrench but couldn't move it at. And I didn't want to start cranking on anything. So can somone give me a holla and let me know.
Old May 13, 2002 | 03:39 PM
keebler65's Avatar
Default Re: Jam nut wrench(valve adjustment) (goforbroke)
if you look at the how-to at c-speedracing.com, you'll see they just modified a craftsman 10mm combo wrench. i would assume you just heat it in a vise and bend it:
hope that gives you a starting point. probably cheaper than a snap-on
Old May 13, 2002 | 03:47 PM
slownslc's Avatar
Default Re: Jam nut wrench(valve adjustment) (keebler65)
Or go buy a crows foot atachment and put it on the end of a ratchet extension. That works fine but they are liek $6 at Sears for a Craftsman.
Old May 14, 2002 | 12:48 AM
carsaregood's Avatar
what i do is i just take my trusty rubber mallet, and gently tap the end of a combination wrench. it works.
jordy478
Aug 7, 2012 08:47 PM
PLAGUED_DB7
Nov 6, 2005 03:30 PM
CardDealer
Mar 8, 2004 08:28 PM
fe519
Jul 3, 2003 07:03 AM
Pineapple Devil
Jun 30, 2003 11:12 AM
