10mm Valve Clearance Adjustment Wrench
Re: 10mm Valve Clearance Adjustment Wrench (2lua)
just adjusted mine last week and couldn't find the tool anywhere local so i modified a 10mm closed end wrecnch. used torches to heat it up worked great
check this site out
http://www.c-speedracing.com/h...t.php
check this site out
Re: 10mm Valve Clearance Adjustment Wrench (schlit)
I dont remember where I saw it but someone on here took a 10mm deep socket and then took a larger combination wrench and beat the enclosed(boxed) end of the wrench over the socket.
Just another option.
Here it is
https://honda-tech.com/zerothread?id=557944
Here it is
TSPeed Factory
Re: 10mm Valve Clearance Adjustment Wrench (func-tion)
yeah i think search under "valve adjustment' and it will show someone making there own tool. it costed like a total of $5 to make and works just as good.
goforbroke
05-14-2002 12:48 AM
