No power brakes STUMPED!
Old Dec 29, 2006 | 12:35 AM
99simoder's Avatar
Default No power brakes STUMPED!
So i took out my old GS-R intake manifold and put a skunk2 in. its working fine now. (motor wise). but now i have no power brakes. (its like driving down the road with your car off trying to brake but all the time) im pretty sure all the hoses are hooked up. could a loose line or bad vacuum seal on the black box canister thing under the manifold by the oil filter cause my braking power to completely fail???
I'm stumped any ideas. oh the motor is a 1994 JDM GS-R in a 99 Si 5sp if that helps any.
any help would be greatly appreciated
Old Dec 29, 2006 | 12:53 AM
Frozen E's Avatar
H-T White Ops
Stupid question, but did you hook the brake booster back up correctly?
The big black hose that used to hook to the back of the intake mani. Because it sounds like it's not on there. Or maybe you somehow got it backwards with the check valve now going the wrong way. Almost impossible to do, but I guess it COULD be done if you tried hard enough if you actually took the line off the brake booster.
Old Dec 29, 2006 | 12:54 AM
99simoder's Avatar
Default Re: No power brakes STUMPED! (99simoder)
on the booster itself? or the lines going down the firewall?
Old Dec 29, 2006 | 12:58 AM
Frozen E's Avatar
H-T White Ops
See where this guy has the line seperated? That's the one I'm talking about. If you somehow have that in backwards, the check valve isn't going to work right.
About the only thing I can think of is that you're not getting good vacuum on that line. Pull it off the intake mani with the motor running and check to make sure that you actually do get a vacuum on the port on the manifold.
Old Dec 29, 2006 | 01:01 AM
99simoder's Avatar
Default Re: (IslandSi)
the hose your talking about runs from the top of the manifold to the booster?
Old Dec 29, 2006 | 01:05 AM
Frozen E's Avatar
H-T White Ops
yeah. just like the pic pretty much.
Old Dec 29, 2006 | 01:06 AM
99simoder's Avatar
k sweet thx.
Old Dec 29, 2006 | 01:09 AM
Frozen E's Avatar
H-T White Ops
Here's what mine looks like.
Mine has a "T" in it to supply the vacuum manifold, but you get the idea. That's a B16 in a 00 Si
Old Dec 29, 2006 | 08:58 AM
JeffBro's Avatar
I am confused on this one. Where the does that T'ed line go to? U said vaccum manifold but it already goes to the manifold above where it's suppose to. I think you hooked something up wrong cause u don't need to T that line.
Old Dec 29, 2006 | 09:02 AM
Frozen E's Avatar
H-T White Ops
Default Re: (JeffBro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeffBro &raquo;</TD></TR><TR><TD CLASS="quote">I am confused on this one. Where the does that T'ed line go to? U said vaccum manifold but it already goes to the manifold above where it's suppose to. I think you hooked something up wrong cause u don't need to T that line.</TD></TR></TABLE>
That's funny. Tell me you're not serious.
maxwellmercer
Jul 15, 2009 10:12 PM
blackhope121
Jan 15, 2008 09:19 PM
Libertariat
10
Oct 18, 2006 12:14 PM
JLefevers
Aug 16, 2006 05:23 AM
