Axles for auto and manual 99 ex civic coupe
I have a 99 civic ex coupe and I am doing a auto to manual swap and need to know if I can re-use the auto axles..
Are they the same part number as the manual axles??
As long as your auto axels are in good condition, they should be fine. There's a c ring on the inside of each axel though. You're suggested to replace it after you pull the axels out of your a/t transmission
Don't try to shortcut and put the axel in without the ring, the axel can pop out for no reason without the clip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jtchinoy »</TD></TR><TR><TD CLASS="quote">As long as your auto axels are in good condition, they should be fine. There's a c ring on the inside of each axel though. You're suggested to replace it after you pull the axels out of your a/t transmission
Don't try to shortcut and put the axel in without the ring, the axel can pop out for no reason without the clip.</TD></TR></TABLE>
oops i put should be
I can't guarantee they're fine... you need your axels coming out fine and your transmission fine... both need to be D-series... after that it'll fit guaranteed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnotiqcivic99 »</TD></TR><TR><TD CLASS="quote">Is this what I need to replace when I do it?
http://replacement.autopartswa...false</TD></TR></TABLE>
http://www.slhondaparts.com/br...=true
part number 9, 44319-SR1-003 SET-RING (26X1.8) (GKN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 »</TD></TR><TR><TD CLASS="quote">
part number 9, 44319-SR1-003 SET-RING (26X1.8) (GKN)</TD></TR></TABLE>
he speaks truth. the axles WILL work. ive done it. replace the ring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrewMD »</TD></TR><TR><TD CLASS="quote">
he speaks truth. the axles WILL work. ive done it. replace the ring.</TD></TR></TABLE>
I know to replace the ring but whats the part number or where can I get it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnotiqcivic99 »</TD></TR><TR><TD CLASS="quote">Not to be rude but I don't want a should be. I need to know for sure and I have no way of finding out. Somone help. Thanks in advanced.</TD></TR></TABLE>
Well spoken.
Yeah they'll work.
Well spoken.
Yeah they'll work.
I know to replace the ring but whats the part number or where can I get it?</TD></TR></TABLE>
Bump...
Bump...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hypnotiqcivic99 »</TD></TR><TR><TD CLASS="quote">I know to replace the ring but whats the part number or where can I get it?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 »</TD></TR><TR><TD CLASS="quote">http://www.slhondaparts.com/br...=true
Honda part #9: 44319-SR1-003 SET-RING (26X1.8) (GKN)</TD></TR></TABLE>
i like posted it up there dude.
blackZC (W)
Dec 30, 2003 03:52 PM
