SI Cluster into DX?
Old Dec 28, 2006 | 07:43 PM
rxmx's Avatar
Default SI Cluster into DX?
I plugged in an SI cluster into my 88 DX hatch, and it didn't work (no tach, etc). Anyone know if this is supposed to be a plug and play swap or have info on how to make it work? Thanks
Old Dec 28, 2006 | 07:51 PM
Tippyman's Avatar
Default Re: SI Cluster into DX? (rxmx)
Did all the plugs hook up perfectly? Did you put the VSS cable back in correctly?
Old Dec 28, 2006 | 08:49 PM
TeamRedline89Hatch's Avatar
What year did the cluster come from?
Old Dec 28, 2006 | 08:50 PM
EL Vap133's Avatar
Default Re: SI Cluster into DX? (TeamRedline89Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamRedline89Hatch &raquo;</TD></TR><TR><TD CLASS="quote">What year did the cluster come from?</TD></TR></TABLE>
Old Dec 29, 2006 | 03:23 PM
rxmx's Avatar
The two big plugs fit fine, but there is a small blue female connection on the back of the SI cluster (maybe 4 pin) that my DX doesn't have.
Old Dec 29, 2006 | 03:26 PM
rxmx's Avatar
Default Re: SI Cluster into DX? (EL Vap133)
I don't know the year of the SI cluster, but it doesn't fit exactly. Seems to have a bit of a curve at the top....my 88 DX seems to be more straight across the top. If this cluster won't work, can I just tap off the blue wire to get a signal to an individual tach? Thanks
Old Dec 29, 2006 | 03:40 PM
VtecSyndrome's Avatar
sounds like you have a 90-91 unit. you just have to repin your plugs to those specs if that's the case. really easy to do.
Old Dec 29, 2006 | 03:42 PM
LatnKng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rxmx &raquo;</TD></TR><TR><TD CLASS="quote">I plugged in an SI cluster into my 88 DX hatch, and it didn't work (no tach, etc). Anyone know if this is supposed to be a plug and play swap or have info on how to make it work? Thanks</TD></TR></TABLE>
It depends on the year, because theres a connector missing on the 88-89 cluster that you'll find on the 90-91 dx and si, that wont just plug in , so you will have a connector hanging, cant recall which one exactly though. sry.
Old Dec 29, 2006 | 03:45 PM
LatnKng's Avatar
Default Re: SI Cluster into DX? (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">Selling any 90-91 CRX Si parts??? let me know cause I am looking for all kinds of misc stuff</TD></TR></TABLE>
I got some 90-91 rex parts, just let me know exactly what u looking for and we'll take it from there. thx
Old Dec 30, 2006 | 02:25 PM
hatchaddict's Avatar
Don't think the housing is gonna fit either.
Old Dec 30, 2006 | 03:08 PM
wood 1's Avatar
There are 2 different manufacturers for the instrument clusters and the wiring is different. You need to find one from the same manufacturer if possible and get the plug from the harness if possible. If you can do this then just repin the wires to match and it should work. 88 to 89 are interchangeable as are the 90 to 91. It is possible to swap between these years but you need the metal mounts and the cluster cover to make it work. Also you will have to rewire the hazard light switch as it is in a different place. I did a write up on the wire color codes a few months ago, but not being a computer whiz, I don't know how to find it. Maybe someone here can help find it. Good luck, it took me a lot of research to get a cluster to work in my son's 89 CRX Si!
Old Dec 31, 2006 | 08:49 AM
rxmx's Avatar
Default Re: SI Cluster into DX? (LatnKng)
Thanks...know where could I find the info on exactly how to repin what plugs? Also, my 90-91? SI cluster is in great shape, 130k miles...will sell cheap or trade for a nice 88-89 SI cluster.
Old Dec 31, 2006 | 09:07 AM
LatnKng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rxmx &raquo;</TD></TR><TR><TD CLASS="quote">Thanks...know where could I find the info on exactly how to repin what plugs? Also, my 90-91? SI cluster is in great shape, 130k miles...will sell cheap or trade for a nice 88-89 SI cluster. </TD></TR></TABLE>
I might can help u on that even trade...hit me back and send pix of the cluster u got..i'll look through my stuff and let u know. thx
Old Jan 2, 2007 | 10:49 PM
rxmx's Avatar
My cluster is from a 90 SI, with 122k, very nice shape.
For a pic, see Ebay listing # below
Item number: 270061587019
Old Jan 3, 2007 | 07:45 AM
LatnKng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rxmx &raquo;</TD></TR><TR><TD CLASS="quote">My cluster is from a 90 SI, with 122k, very nice shape.
Well let me know if u want to trade, and we can do it. I'm in Georgia.
Old Jan 4, 2007 | 08:43 PM
rxmx's Avatar
If you have a good 88-89 SI cluster, I'll trade. Any info on wiring changes needed to make it work on my DX? Email a pic if you have one...cavok800@yahoo.com
Old Jan 9, 2007 | 07:57 PM
thedudefromjerz's Avatar
I have a 90 dx wit no rpms on the cluster. My friend gave me what i think is an 89 si cluster cuz it has rpm's and no blue plug on the back. when i hooked it up to my dx nothing worked except the batt. light. how can i get it to work or should i search for a 90-91 si cluster?
Old Jan 9, 2007 | 08:14 PM
EFHATCHMAN's Avatar
HEY I HAVE AN 88-89 SI CLUSTER IN GOOD SHAPE IF YOU WANT TO TRADE. THE ONLY THING IS IT SHOWS 261,XXX MILES... LET ME KNOW!
Old Jan 10, 2007 | 03:50 AM
Hondaisok's Avatar
I had the same problem when I recently bought a cluster from ebay. The ad stated fits, any 89-91 civic, but when it arrived, it didn't have a female plug for the blue plug. Also, when I plugged everything else in, the tach for one did not work.
This instrument cluster is straight across, while the one from my 91 LX and STD are rounded at the top.
Further research indicates the one that I needed is from an SI, which would have a curved top, while the one from the CRX is straight across. I found it on a search on this forum. Anyway, it appears that it would work if you repinned.
Old Jan 10, 2007 | 05:54 AM
Default Re: SI Cluster into DX? (Hondaisok)
Ok thanks for the info. Im not to familiar with electrical work so would you mind describing what I would have to depin. thanks
Old Jan 10, 2007 | 06:00 AM
Hondaisok's Avatar
Default Re: SI Cluster into DX? (thedudefromjerz)
I didn't actually repin mine, I'm going to sell it on ebay and get the right one so I don't have to repin (I'm not so sure everything would work right, i.e. all of the lights).
If you do a search on this forum you will find the write-up on it. Someone on here did an excellent job writing it up with pics and all.
Old Jan 13, 2007 | 05:16 PM
90redintegra's Avatar
I have 88-89 si cluster with straight top 177,301 miles. I'm in search for 90-91 si with curve top. I will trade if you got one.
Old Jan 14, 2007 | 10:03 PM
rxmx's Avatar
Default Re: SI Cluster into DX? (90redintegra)
My cluster is from a 90 SI, curved top, with 122k. Real nice shape. I'll trade it for your 88/89 straight top Si. Shoot me an email cavok800@yahoo.com
Old Jan 15, 2007 | 07:23 AM
gibsanez's Avatar
try to keep it to pm's or the for sale section, it clutters up the threads
DonDinero
Honda Civic (2001 - 2005)
Jan 8, 2008 04:50 PM
Mr.Meowsome
12
Dec 4, 2007 05:23 PM
143MYVTECEF
13
Jun 9, 2007 04:22 AM
89sicivic
May 25, 2006 10:43 AM
NightHawkC5
10
May 23, 2006 04:42 AM
