del slow disc brakes on eg
Old Dec 28, 2006 | 06:41 PM
preludedriva's Avatar
Default del slow disc brakes on eg
hey i was wondering if the rear disc brakes off a del slow will fit on a 92-95 civic h/b (e-brake lines the same) ?
Old Dec 28, 2006 | 07:57 PM
EL Vap133's Avatar
Default Re: del slow disc brakes on eg (preludedriva)
Yes they will fit.
Look here for any info: https://honda-tech.com/zerothread/642479
Old Dec 28, 2006 | 08:03 PM
pdiggitydogg's Avatar
cables are different
get cables for an eg si hatch
Old Dec 28, 2006 | 08:04 PM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">E- brake cables are different
get cables for an eg si hatch</TD></TR></TABLE>in case he didnt know which cables
Old Dec 28, 2006 | 09:59 PM
OnlyHJC's Avatar
Default Re: (honda 3300)
you should grab the lower control arms too if it have the sway bars on it
Old Dec 28, 2006 | 11:08 PM
junior40er's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">cables are different
get cables for an eg si hatch</TD></TR></TABLE> are you SURE about that? del sol/eg hatches have same E-brake cables from what I understand.
Old Dec 29, 2006 | 12:56 AM
BlueIntegraBoy's Avatar
Default Re: (junior40er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote"> are you SURE about that? del sol/eg hatches have same E-brake cables from what I understand.</TD></TR></TABLE>
They don't. I have Del Sol rear discs on my hatch. The Del Sol cables are shorter. I used Integra cables instead.
Old Dec 29, 2006 | 01:24 AM
fasterthanueg's Avatar
how do you get the cables off then
Old Dec 29, 2006 | 04:01 AM
Just follow the cable toward the caliper, remove the caliper shield (2 10mm bolts), pull out the cotter, and finally remove clevis pin that holds cable in place.
Once you remove that shield, you'll be able to figure it out.
Old Dec 29, 2006 | 08:45 AM
junior40er's Avatar
Default Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
They don't. I have Del Sol rear discs on my hatch. The Del Sol cables are shorter. I used Integra cables instead.</TD></TR></TABLE>
so my del sol cab;es wont work but a dc integra e brake cable should??
civic_driver_389
Aug 25, 2007 06:09 AM
Fatty_1775
22
Jun 25, 2006 07:33 PM
Hatch It
Dec 24, 2004 07:43 PM
gillyfesh
Mar 27, 2004 08:00 PM
Redlined-EH3
Dec 5, 2003 07:22 PM
