Need pics of jdm4-1 with upper heatshield, engine bay pic pls.
i am thinkin bout gettin an upper heatshield for my jdm 4-1.
just wanna c how/what it looks like
like stock>?
ok, where else can i pick up one of these in the bay
like stock>?
There's a good pic here:
http://www.fastlineperformance.com/products.htm
It's at the bottom (click to enlarge it).
HTH,
- Slater
HTH,
- Slater
how many bolts are required to put the jdm heatshield on the header?
also, are these just bolts, or do u need nuts on the other side.
i only have 3-4 right now that i think i can find,
wut size do i need just in case i dont have em..
thanks
thanks
Header? What header??
Only way you can see it is to lean in to the right of the shield as you're facing the car. You can see a bit of tube hanging out. If you don't know what you're looking for, you will not find it.
[edit] What Will said - five bolts [/edit]
[Modified by itr009, 11:31 PM 5/23/2002]
Damn, so what's a lower heat shield?
-skafia, hoping that the UPS man isn't running the newly ordered JDM 4-1 on the big brown truck.
[Modified by skafia, 9:14 PM 5/23/2002]
By the way... how heavy is the upper heat shield? is it worth having the extra weight for the lower engine bay temp?
UPS weighed my header/heat shield together and it came out to 27.40 lbs, how heavy is a stock ITR exhaust manifold?
[Modified by skafia, 9:19 PM 5/23/2002]
Upper shield is not heavy enough to even notice. Pound or two, at the most. Underhood temps are dramatically lower.
the upper heatshield is also important...
for being stealthy in the face of Pignosed copz
How does the heatshield lower underhood temps? I wouldn't think it would reduce the heat (it doesn't take it anywhere), or does it just contain the heat in a smaller area? My replacement header doesn't have a shield, which didn't bother me at all until I read this thread...
Drinker
