catch pans anyone started on them yet?
Old Dec 28, 2006 | 03:31 PM
MrParks's Avatar
Default catch pans anyone started on them yet?
has anyone started to make the revised ones for 07? with 2" sides
Old Dec 28, 2006 | 03:55 PM
FMUNK's Avatar
Default Re: catch pans anyone started on them yet? (GHOSTWORKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GHOSTWORKS &raquo;</TD></TR><TR><TD CLASS="quote">has anyone started to make the revised ones for 07? with 2" sides</TD></TR></TABLE>2" sides were required last year. They were also supposed to be angled back inward to prevent sloshing over the edge.
Our pan was the only one I saw that met those requirements last season.
Ours was Stainless Steel.............that is going to be changed to aluminum.(was strong but heavy)
Old Dec 28, 2006 | 07:39 PM
MrParks's Avatar
Default Re: catch pans anyone started on them yet? (FMUNK)
i swore it was 1"
Old Dec 28, 2006 | 07:41 PM
Tyler H's Avatar
Mine was only 1" last year, but I'm a rebel like that...
It was 1" lips last year, for SFWD at least. I'm probably just going to mod my current catch pan. It'll be pretty easy to add another inch to the rails.
Old Dec 28, 2006 | 08:10 PM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FMUNK &raquo;</TD></TR><TR><TD CLASS="quote">2" sides were required last year. They were also supposed to be angled back inward to prevent sloshing over the edge.
Ours was Stainless Steel.............that is going to be changed to aluminum.(was strong but heavy)</TD></TR></TABLE>
i didnt know it was a requirement to have 2inch lips as of last year..
removing the old "lips" and installing newer taller chanel should be a no brainer for most.
Old Dec 28, 2006 | 08:17 PM
MrParks's Avatar
Default Re: catch pans anyone started on them yet? (dturbocivic)
it stated that the pan has to cover the radiator back and frame rail to frame rail.
Old Dec 28, 2006 | 09:00 PM
FMUNK's Avatar
I belive it was only 1 inch for streetcars.
It may have just been 1inch, I cannot find the old book. I knoe the enges were supposed to be curved inward. I built it with the rulebook sitting beside me. That is the only reason I had the edges curved in on ours was because I read it out of the rulebook.
Old Dec 28, 2006 | 10:04 PM
Suprdave's Avatar
This is for 2007 NHRA right? Is it for any car? Someone post up the rule for me please.
Old Dec 28, 2006 | 10:07 PM
dragginyo's Avatar
76.114.1.188
yeah it was like working to u know without loosing much of blown motor parts out there on the track... so i guess they will also regulate that for 2007 too huh. well need to make a new one last one was good enough but was a last minute job u know...
Old Dec 29, 2006 | 06:19 AM
TDautowerkes's Avatar
Default Re: catch pans anyone started on them yet? (dragginyo)
we fabricate pans and have them in stock.....
weve had them since last year and already were 2 inch lips
https://honda-tech.com/zerothread/1842498
Old Dec 29, 2006 | 10:26 AM
Blind_Attack's Avatar
what about the mazworx ones?
Old Dec 29, 2006 | 11:35 AM
is there a real diference between a diaper or a pan? i mean besides the material? both acomplish the same thing correct?
Old Dec 29, 2006 | 12:44 PM
jpenman50's Avatar
Default Re: (rota92)
The diaper will not work... As for 2008, the new requirments is a diaper and a catch pan... I am revising the pans from last season... The cost on the units are 180.00 plus shipping... They ship as 2 pieces... They are from radiator support to the firewall, and come with universal hardware.. Material is made of aluminum
Old Dec 29, 2006 | 01:46 PM
dome's Avatar
Default Re: (jpenman50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpenman50 &raquo;</TD></TR><TR><TD CLASS="quote">The diaper will not work... As for 2008, the new requirments is a diaper and a catch pan... I am revising the pans from last season... The cost on the units are 180.00 plus shipping... They ship as 2 pieces... They are from radiator support to the firewall, and come with universal hardware.. Material is made of aluminum</TD></TR></TABLE>
you got any pics of the pan
Old Dec 29, 2006 | 02:54 PM
HR-1320's Avatar
Default Re: (dome)
I didn't see anything about angled inward.
Old Dec 29, 2006 | 04:53 PM
GrinderGuy2's Avatar
The season after next
Old Dec 29, 2006 | 05:27 PM
OaksRacing's Avatar
I think the 2" lip with a snap in diaper at the bottom of the pan would be a better ideal than adding the diaper in 2008. With the exhaust pipe going under the oil pan a diaper is a difficult fit. If NHRA reads this post let us know what you think.
Sr.
Old Dec 29, 2006 | 06:02 PM
Axle's Avatar
Default Re: catch pans anyone started on them yet? (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">This is for 2007 NHRA right? Is it for any car? Someone post up the rule for me please. </TD></TR></TABLE>
From the SFWD section:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NHRA Sport Compact Rulebook 2007 &raquo;</TD></TR><TR><TD CLASS="quote">
ENGINE CONTAINMENT DEVICE:
Engine diaper or catch-pan device to capture oil and debris in
event of engine failure mandatory. Where exhaust header passes
directly under oil pan, two-piece diaper may be utilized. FWD
vehicles using OEM manual-transmission case must also have
such a device for the transmission, to capture oil and debris in
event of transmission failure. If catch-pan device is used, catch pan
must employ minimum 2-inch-high lips on all sides. Lips must be coved or curved inward, so as to contain oil in pan. Catch pan
must cover entire area below engine/transmission. Catch pan must
extend from radiator support to firewall and from framerail to
framerail. In all cases, lips must be adequate enough to contain oil
in the catch pan. Should a competitor spill excessive oil from the
catch pan and debris onto the track, he or she may be disqualified
from further competition at the sole and absolute discretion of the
event director until catch pan is upgraded, regardless of height of
pan lips or pan design. Both engine diapers and catch pans
mandatory for 2008.
Old Dec 29, 2006 | 10:15 PM
reaction360's Avatar
Default Re: catch pans anyone started on them yet? (Axle)
i thought they had to be SFI approved?
Old Dec 31, 2006 | 11:33 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpenman50 &raquo;</TD></TR><TR><TD CLASS="quote">The cost on the units are 180.00 plus shipping... They ship as 2 pieces... They are from radiator support to the firewall, and come with universal hardware.. Material is made of aluminum</TD></TR></TABLE>post pictures!
b20zvtec
Dec 1, 2006 10:25 AM
chad
331
Mar 26, 2005 04:34 AM
RACEPAK
27
Nov 1, 2004 03:49 AM
SwiftTypeR
Jul 3, 2004 05:16 AM
shming123
Apr 9, 2003 03:51 PM
