Toda A's worth it?
Old May 13, 2002 | 12:07 PM
Hard2Find's Avatar
Default Toda A's worth it?
is it worth getting a Toda A's? so that we can keep the stock ITR springs and retainers?
or
go through all the hassle of maintaining and checking when we get a Toda B's with portflow, etc..
money is not an issue since its only small difference. Plus, this is daily driven and weekend street racing car.
Whats do you think?
Old May 13, 2002 | 12:22 PM
Black R's Avatar
25 Year Member
Default Re: Toda A's worth it? (Hard2Find)
.....depends on what you're looking for.
How far do you want to go, what's your budget, goal, etc?
Todd00's Avatar
I said I don't want a title!
Parts, maybe not. Labor and time--it is a huge difference between the two.
A's are good cams and great because they play nicely with the stock R stuff. Plus, they will make a lot of power. B's require many upgrades for safely revving, getting max power, etc.
Old May 13, 2002 | 01:01 PM
Mike K's Avatar
Default Re: Toda A's worth it? (Todd00)
Toda A's? Yes, very much worth it.
Stock springs are fine. They make peak power around 7800 anyway.
Old May 13, 2002 | 01:02 PM
sneakychaos's Avatar
Default Re: Toda A's worth it? (Mike K)
What kinda numbers have you seen with the A's? (HP/TQ)
Old May 13, 2002 | 01:04 PM
Hard2Find's Avatar
Default Re: Toda A's worth it? (trooth)
thats exactly my question too...
what kinda power are you looking at when its tuned with stock internals...just intake, headers, exhaust?
Old May 13, 2002 | 01:15 PM
Black R's Avatar
25 Year Member
What kinda numbers have you seen with the A's? (HP/TQ) thats exactly my question too...
with A's, B's, or C's, you're looking at roughly the same PEAK numbers - mid to high 180's to low 190's... depending on mods and tuning. This is stock compression. The difference is that B's and C's will make more peak with more compression, and more midrange than A's in any configuration.....
Old May 13, 2002 | 01:30 PM
Default Re: Toda A's worth it? (Black R)
Black R - nice avatar, like woah.
Good to know about peak HP though.
Old May 13, 2002 | 01:47 PM
Hard2Find's Avatar
you are saying that Toda A's makes same peak power as B/C???
so, with stock compression, and I/H/E, Toda A is good enough for 180-190whp?
Old May 13, 2002 | 01:52 PM
Rob :190:'s Avatar
peak yes. a A-equipped R may have the same peak numbers as a B/C motor, but in a race the B/C car will walk all over the A car due to the area under the curve....
Old May 13, 2002 | 01:58 PM
Reid's Avatar
Global Moderator
If this is what you use the car for, forget N/A. Save up and get a turbo. Boost 0wnz on the street... and on the track.
Old May 13, 2002 | 02:10 PM
Hard2Find's Avatar
Default Re: Toda A's worth it? (Reid)
Reliability oWnZ hehe
if we wanted a turbo car, he would have bought a LS or GSR...not ITR
Old May 13, 2002 | 02:12 PM
Hard2Find's Avatar
Default Re: Toda A's worth it? (Brian Spilner 1035)
anyone have a dyno plot of Toda As vs Bs vs. Jun3s?
Old May 13, 2002 | 02:17 PM
Reid's Avatar
Global Moderator
Tuning is the key to reliability, whether it's N/A, S/C or turbo. I really don't care which route you choose, since you seem to have your mind set on N/A.
Go with Toda A's if reliability is a big concern to you.
Just stay away from those turbo ITRs, lest they smack you around.
Old May 13, 2002 | 02:38 PM
Hard2Find's Avatar
shiet, i dont mind having a turbo...just that its too much of a hassle....plus, im not about to build my stock block yet. its a 2000 motor.
i dont think a stock turbo itr can handle the beating im doing with my NA, thats why im staying with NA
Old May 13, 2002 | 09:05 PM
Black R's Avatar
25 Year Member
.....try http://www.sgt-racing.com
Old May 13, 2002 | 09:59 PM
vpc's Avatar
vpc
New User
do a search under Mike K's screen name. He posted results from the Great Cam test with jun vs toda cams on a b18c5.
Old May 13, 2002 | 10:16 PM
Mike M's Avatar
Founding Member
Edit - mixed up 2 members
Old May 13, 2002 | 11:45 PM
EagleR's Avatar
Area under the curve...often neglected and far more important than peak
Old May 14, 2002 | 04:54 AM
SpoonFed's Avatar
I have some Toda B's for sale....
Old May 14, 2002 | 08:01 AM
Black R's Avatar
25 Year Member
Oh yeah, I forgot to reply to the original question:
IMHO: YES, whether it be A's, B's, or C's...
I've been very happy with B's and now C's.
Old May 14, 2002 | 08:13 AM
b18b98's Avatar
Toda Bs
Old May 14, 2002 | 09:58 AM
nsx-Animal's Avatar
I't depends what you want from your car. Toda A's would be a non agressive setup. If all you want is to go fast from point A to point B (1/4 mile racing) them get a Turbo. No cam setup can come close to a Turbo setup. Now if you want reliability then Tada A's are a nice addition. No funky Idle, you don't need to mod internals (spring, etc..) and you can make some great power if tuned correctly.
Old May 15, 2002 | 01:32 AM
TypeR_853's Avatar
Default Re: Toda A's worth it? (Itr-Animal)
proper tuning plays one of the biggest factors...but if you're going n/a and planning to get crazy, go with the spec b. if you just want to keep your stock stuff, go with spec a. turbo is only an option if you have the patience to learn it and know how to maintain it...driving turbo is totally different than n/a too. g'luck man...
ricekiller1
Nov 27, 2007 11:25 PM
JDM TypeR 307
Dec 29, 2003 02:13 AM
bitr364
Mar 9, 2003 12:54 AM
Hard2Find
May 2, 2002 04:39 PM
GQ 05YellowEVO8
Jan 2, 2002 01:51 PM
