Suspension & Brakes Theory, alignment, spring rates....
Hit the curb - Results inside
Old Dec 28, 2006 | 08:31 AM
Mohsin's Avatar
Default Hit the curb - Results inside
Hello All,
Car went into the curb at 20ish, was turning left at cross road whilst the wheel was 3/4 locked to the left, half of the alloy lip is grazed but no dent
Here are the results After alignment, only front two wheels adjusted:
FR - Front Right | FL - Front Left || RL - Rear Left | RR - Rear Right
Caster:
FR: -0.24
FL: 0.59
Camber:
FR: -0.21
FL: -1.16
RL: -1.16
RR: -1.13
Toe:
FR: 0.06
FL: 0.01
RL: 0.04
RR: 0.09
Steering pulls slightly to right, could this be a bent track rod? Or something else?
Old Dec 28, 2006 | 09:44 AM
Oleg's Avatar
Default Re: Hit the curb - Results inside (Mohsin)
you just wasted your time doing alignment with the bent parts.....even though you got toe back in your camber shows that something elese is fucked. The only shure way to figure that out is to measure your control arms, etc to figure out what is bent....good luck man.
Old Dec 28, 2006 | 11:30 AM
Tyson's Avatar
Default Re: Hit the curb - Results inside (Oleg)
i dont think it was a WASTE of time doing the alignment. you know for sure now whats bent and how much it has affectd your alignment. and well, its affected it a lot.
hard to say whats bent tho. most probable suspects are the typical LCA and maybe a bent knuckle because that camber is off too. check out the subframe and make sure theres no damage either.
if you dont know how to check any of this out, then take it to a shop.
Old Dec 28, 2006 | 02:11 PM
Mohsin's Avatar
Default Re: Hit the curb - Results inside (Tyson)
oh right, havnt really had time to jack it up, can anyone explain what the knuckle is and where it's located?
Should I find an oem set of front lca's or buy the omni lca's?
Front right (driver side) hit the curb for reference
Old Dec 29, 2006 | 07:52 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mohsin &raquo;</TD></TR><TR><TD CLASS="quote">oh right, havnt really had time to jack it up, can anyone explain what the knuckle is and where it's located?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
if you dont know how to check any of this out, then take it to a shop.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
Should I find an oem set of front lca's or buy the omni lca's?</TD></TR></TABLE>
thats like piling crap in a crap hole.
Old Dec 29, 2006 | 10:10 AM
spoonef's Avatar
6-8 is the knuckle and 11-13 is your upper control arm.Check for anything out of the ordinary(bent pieces).
Old Dec 29, 2006 | 01:18 PM
FalkenSiR's Avatar
Default Re: Hit the curb - Results inside (spoonef)
I had the same thing happen to me. But I hit one at like 30+
My FR LCA was bent to hell and I replaced it and it's been fine since then. No other suspension damage to be felt or seen. However, I lost steering returnability. I do have the parts to rebuild my steering, tho. I just haven't done it yet.
Old Dec 29, 2006 | 05:51 PM
Tyson's Avatar
Default Re: Hit the curb - Results inside (FalkenSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FalkenSiR &raquo;</TD></TR><TR><TD CLASS="quote"> However, I lost steering returnability. </TD></TR></TABLE>
you still have issues.
Old Dec 29, 2006 | 11:47 PM
Mohsin's Avatar
if you lost steering returnability, wouldn't this be the track rod end? Since this is the cpt that normally plays up that leads to saggy steering / returnability.
pKjai
Suspension & Brakes
Oct 27, 2010 08:28 PM
00IntegrAllmotoR
Suspension & Brakes
16
Oct 24, 2009 07:08 PM
00IntegrAllmotoR
Aug 12, 2009 06:48 PM
BeyondRedline
Oct 4, 2001 01:03 PM
