Need help Amp flashing from clip to protected mode
Old Dec 28, 2006 | 08:09 AM
rutherfordhigh's Avatar
Default Need help Amp flashing from clip to protected mode
Was working fine untill yesterday! Have infinity amp powering 4 infinity speakers! Driving home and heard a bumping soud out of front left speaker, then all speakers stoped working! When to the back and the amp keeps flashing from clip to protected mode! Any ideas on what could be wrong? How to fix? Thanks
Old Dec 28, 2006 | 11:29 AM
94_DC4's Avatar
Default Re: Need help Amp flashing from clip to protected mode (rutherfordhigh)
Check the speaker wiring. Probably came loose and is shorting out.
Old Dec 28, 2006 | 12:17 PM
8520's Avatar
Default Re: Need help Amp flashing from clip to protected mode (94_DC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_DC4 &raquo;</TD></TR><TR><TD CLASS="quote">Check the speaker wiring. Probably came loose and is shorting out.</TD></TR></TABLE>
I agree
Old Dec 28, 2006 | 03:28 PM
fcm's Avatar
fcm
Old Fart
Ditto both the above, I would pull the front left speaker and check the wiring, also make sure speaker terminals are not making contact with the the doors metal skin, with some aftermarket speakers the terminals are located in such a manner that they will make contact, but work for a while, [because of the paint] then short out.
If the above is the case as soon as you pull the speaker, the amp will start working properly again, I would not use the system until problem is found, even with protection circuits, it is not good to short the output of an amp.
Also if the left has the problem it's a good bet you will have the same problem on the right at some point. 94
Old Dec 29, 2006 | 05:35 AM
Tryed it in my friends car it did the same thing! He has the same set up as me! Any ideas?
Old Dec 29, 2006 | 06:37 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rutherfordhigh &raquo;</TD></TR><TR><TD CLASS="quote">Tryed it in my friends car it did the same thing! He has the same set up as me! Any ideas?</TD></TR></TABLE> Either your friend also has a problem with the front left speaker or you have a problem with your amp, or you still have a problem with your front left speaker and it damaged the amps front left output and that's why you also have the problem in your friends car. 94
nenetech
Audio / Security / Video
Aug 17, 2010 10:30 AM
TheTealHatch
23
Oct 11, 2006 08:05 PM
TheTealHatch
Aug 22, 2006 12:53 PM
jdmtuner64
Aug 21, 2006 09:14 AM
Jer'rome
May 24, 2003 03:34 PM
