Bogging VTEC...
Old Dec 27, 2006 | 10:58 PM
del Slo SiR's Avatar
Default Bogging VTEC...
Posting this for a friend...
He just got a 99 Si and the stock B16A2 except for a no name intake...it runs ok before it goes into VTEC but right before it goes into VTEC there is a loud hissing noise and you can really hear VTEC but the car goes no where...I had this problem in my Sol and I just ripped on it and it snapped out of it but I dont know whats going on with his car...We changed the Oil, Oil filter, spark plugs and I took off the VTEC Solenoid and didnt see any clogs and we replaced that gasket as well...any help would be great...oh almost forgot there is no CEL...
Old Dec 27, 2006 | 11:06 PM
Jimmy's Avatar
Global Moderator
How bad of a ''bog''
Feel like fuel cutting off?
Old Dec 27, 2006 | 11:12 PM
Default Re: (Jimmy)
I'm not sure if its lack of fuel...it fells like its choking...VTEC screams but it doesnt pick up
Old Dec 27, 2006 | 11:13 PM
jdmjaser's Avatar
Default Re: (Jimmy)
the intake filter mite be clod....it happen to me...
Old Dec 27, 2006 | 11:21 PM
51-50ej7's Avatar
Default Re: Bogging VTEC... (delSloSiR626)
check your oil pressure and oil level.
Old Dec 27, 2006 | 11:24 PM
Jimmy's Avatar
Global Moderator
Default Re: Bogging VTEC... (51-50ej7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 51-50ej7 &raquo;</TD></TR><TR><TD CLASS="quote">check your oil pressure and oil level.</TD></TR></TABLE>
I'm gonna pre assume that his oil level is fine hence he just done an oil change.
Old Dec 27, 2006 | 11:27 PM
Default Re: (jdmjaser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjaser &raquo;</TD></TR><TR><TD CLASS="quote">the intake filter mite be clod....it happen to me...</TD></TR></TABLE>
hahahaha...NO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">I'm gonna pre assume that his oil level is fine hence he just done an oil change.</TD></TR></TABLE>
Old Dec 27, 2006 | 11:28 PM
Jimmy's Avatar
Global Moderator
Have you changed the fuel filter ever? Got gas somewhere you haven't before?
Old Dec 27, 2006 | 11:30 PM
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Have you changed the fuel filter ever? Got gas somewhere you haven't before?</TD></TR></TABLE>
Doubt it...this Si was neglected by his cousin...I have never chnage mine either...are u thinkin it might be clogged? we added that Lucas injector cleaner stuff
Old Dec 27, 2006 | 11:32 PM
Jimmy's Avatar
Global Moderator
Default Re: (delSloSiR626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delSloSiR626 &raquo;</TD></TR><TR><TD CLASS="quote">Doibt it...this Si was neglected by his cousin...</TD></TR></TABLE>
Have you checked timing, dist cap, rotor button, run some fuel injector cleaner,etc.
EM1Michael3589's Avatar
Default Re: (Jimmy)
its my si and when it gets into vtec it makes a loud clicking noise i cant figure it out
Old Dec 27, 2006 | 11:34 PM
Jimmy's Avatar
Global Moderator
Default Re: (EM1Michael3589)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1Michael3589 &raquo;</TD></TR><TR><TD CLASS="quote">its my si and when it gets into vtec it makes a loud clicking noise i cant figure it out </TD></TR></TABLE>
I can't duplicate the sound, but i'm sure if i were there i could help..
Maybe the VTEC solenoid?
Old Dec 27, 2006 | 11:37 PM
Default Re: (Jimmy)
just changed it
im going to make a clip of it so you can hear what it sounds like
Old Dec 27, 2006 | 11:38 PM
Default Re: (Jimmy)
Advanced the timing and nada...trying to find a OBD2 VTEC dizzy to see if thats the problem might swap solenoids...if it comes down to it...we will hopefully have a VID/sound clip up tomorrow...
Old Dec 27, 2006 | 11:47 PM
Jimmy's Avatar
Global Moderator
Get the clip up when you can, but the timing needs to be stock and if you've advanced the timing depending on how much you'll need to run higher octane gas.
All Motor Ek99's Avatar
lol its not a bog... its more like the car has no power in vtec watsoever.. vtec pops loud just it doesnt go anywhere and hisses like there is a valve floating somewhere
Old Dec 28, 2006 | 12:14 AM
Jimmy's Avatar
Global Moderator
Default Re: (NA-Ef8 (Socal Moderator))
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA-Ef8 (Socal Moderator) &raquo;</TD></TR><TR><TD CLASS="quote">lol its not a bog... its more like the car has no power in vtec watsoever.. vtec pops loud just it doesnt go anywhere and hisses like there is a valve floating somewhere</TD></TR></TABLE>
I think the problem is your experiencing the powerband of a bone stock B16
::waits on video::
Goodluck bro.
Old Dec 28, 2006 | 05:12 AM
TheAccordGuy's Avatar
Having the same problem as well with my b16a2 vtec is working but the car not going any where but this just started happening recently. About 2 weeks the car moved in vtec like my h22 accord bone stock in my hatch. Anyone that claims that a bone stock b16 has weak vtec has never driven a b16 that actually running good. Vtec moves hard in this motor when it working right. I believe my probelm is becuase I put to much oil in my car.
Old Dec 28, 2006 | 06:43 AM
Jimmy's Avatar
Global Moderator
Default Re: (TheAccordGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheAccordGuy &raquo;</TD></TR><TR><TD CLASS="quote">Having the same problem as well with my b16a2 vtec is working but the car not going any where but this just started happening recently. About 2 weeks the car moved in vtec like my h22 accord bone stock in my hatch. Anyone that claims that a bone stock b16 has weak vtec has never driven a b16 that actually running good. Vtec moves hard in this motor when it working right. I believe my probelm is becuase I put to much oil in my car.</TD></TR></TABLE>
I'm preassuming your referring to me, Because i know i wouldn't be driving a b16 that's running right.. Because I'm driving a 12:5:1 built b18c1 & yes a stock b16 running right is still ******* weaksauce.
If you believe your problem is your oil being overfilled.. Pull the dipstick and check your oil level and drain some dumbass.
To the original thread poster, hit me up when you get the video!
Old Dec 28, 2006 | 07:02 AM
oneslowstd's Avatar
Thats what B16A2 do, they are dog slow! Why I don't know? But every Si I have ridden in, felt poopish! Only thing I can think of is weight
Old Dec 28, 2006 | 07:35 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: Bogging VTEC... (oneslowstd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowstd &raquo;</TD></TR><TR><TD CLASS="quote">Thats what B16A2 do, they are dog slow! Why I don't know? But every Si I have ridden in, felt poopish! Only thing I can think of is weight</TD></TR></TABLE>
Shut up.
That hissing sound is oil pressure. Either your car's not warmed up, or something wrong with your oil pressure. I had that problem.
4 qts of oil(5w-30)
Timing at 16
91+ octane
^^^Is all this correct?
What's the CEL for?
Old Dec 28, 2006 | 07:50 AM
Default Re: Bogging VTEC... (black_EM1)
yeah thats all right
but the thing is, there is no cel
Old Dec 28, 2006 | 07:53 AM
Jimmy's Avatar
Global Moderator
Default Re: Bogging VTEC... (EM1Michael3589)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1Michael3589 &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats all right
Well do you see the cel flash on when you turn the key on? You said this car was neglected.. They could of pulled the bulb out of the cluster.. I'm gonna start naming all kinds of ghetto ****
Old Dec 28, 2006 | 07:55 AM
Default Re: Bogging VTEC... (Jimmy)
lol i dont know ill have to check but ill have the video up pretty soon ok
Old Dec 28, 2006 | 08:38 AM
Mikes2000civicsi's Avatar
before my old stock 99 si was stolen,vtec was the ****,hits hartd even on a b16(i was driving a d16 before) for figurung it out
