web cams valve clearance?
Old Dec 27, 2006 | 08:37 PM
JDM97EK's Avatar
Default web cams valve clearance?
My buddy just gave me a set of new web cams. The catch is, that he has no paperwork of any kind. they are stamped "web cam" on the end that is about it. I am wondering what the valve clearance should be. Anyone know exactly? O yeah..... its for a b18c1 motor thanks
Old Dec 28, 2006 | 09:47 AM
LSVTEC 91 Civic's Avatar
Banned
Well, when I called them up, they said no tighter than .008" on both sides. It's always been a little noisy, but I'm sticking with their recommendations.
Old Dec 28, 2006 | 10:30 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (LSVTEC 91 Civic)
I was wondering when you would see this.
Old Dec 28, 2006 | 11:24 AM
Combustion Contraption's Avatar
Sheepey?
Old Dec 28, 2006 | 11:39 AM
black_EM1's Avatar
Community Builder
Default Re: (black_EM1)
No, not me man. ^^^That's my good friend, Manny. He's got a set of Webs.
Old Dec 28, 2006 | 11:44 AM
Banned
Nah I called Web directly.
Old Dec 28, 2006 | 11:48 AM
black_EM1's Avatar
Community Builder
Aren't you special.
Old Dec 28, 2006 | 11:49 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_EM1 &raquo;</TD></TR><TR><TD CLASS="quote">Aren't you special. </TD></TR></TABLE>
Nice postwhoring skills, Charles.
Old Jan 2, 2007 | 11:57 AM
Rocket's Avatar
I would do 0.006/0.008.
Web uses a a smaller base circle and this is one of the reasons I say 6/8 as opposed to 7/9 as my usual recommendation on perf. cams.
You may need to play with the lash to see what you and the motor like.
Old Jan 2, 2007 | 03:31 PM
d16dcoe45's Avatar
Default Re: (Don Lackey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Lackey &raquo;</TD></TR><TR><TD CLASS="quote">I would do 0.006/0.008.
You may need to play with the lash to see what you and the motor like.</TD></TR></TABLE>Why would have a smaller base circle be better with 6/8 as opposed to 7/9? I am running a reground small base circle cam and am using 7/9--would I be better off 6/8?
Old Jan 2, 2007 | 03:55 PM
DonF's Avatar
Default Re: (d16dcoe45)
Depends if you have a new or used feeler guage. Snap-On or KD. The diff. between .006 and .007 is less than 1/4 of a RCH. What is the actual clearance with the rocker arm ratio?
Old Jan 3, 2007 | 05:21 AM
d16dcoe45's Avatar
Default Re: (DonF)
Don, are you asking what the actual clearance at the cam is using 7/9 at the valve--isn't a d16a6 rocker around 1.5? So 7 divided by 1.5 and 9 divided by 1.5=0.0047 and 0.006" respectively unless I misunderstood what you are asking.
Old Jan 8, 2007 | 11:46 AM
Rocket's Avatar
Too a certain extent lash is dependant on the size of the base circle.
Bigger base circle increase the lash and vice versa.
J-Spot
22
Sep 27, 2007 10:15 AM
Scubster
Apr 26, 2007 03:14 PM
vtec25
Dec 31, 2006 11:54 AM
DEMNTD1
Sep 27, 2005 09:17 PM
cancer
Dec 21, 2004 10:32 PM
