does anyone know how too.....
Old Dec 27, 2006 | 07:27 PM
LSTEG98's Avatar
Default does anyone know how too.....
lift your hood in the back??? how do you do it???
Old Dec 27, 2006 | 07:28 PM
black7hatch's Avatar
Default Re: does anyone know how too..... (LSTEG98)
your joking me right?
Old Dec 27, 2006 | 07:29 PM
LSTEG98's Avatar
if i was joking would i post that?? lol wat da
Old Dec 27, 2006 | 07:31 PM
LSTEG98's Avatar
by asking that i mean to let some heat out on turbo whips by lifting the back part of the hood
Old Dec 27, 2006 | 09:14 PM
Tranzy [ej1luv]'s Avatar
Use WASHERS.
Old Dec 27, 2006 | 09:15 PM
JDM-EJ1's Avatar
Default Re: does anyone know how too..... (black7hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black7hatch &raquo;</TD></TR><TR><TD CLASS="quote">your joking me right?</TD></TR></TABLE>
**** off. The guy asked a legitimate questions, if you have a problem with what he wants to do with HIS car than you can leave. Thanks for your understanding.
You'll want to use washers on the back bolt on each side of your hood hinge's.
Modified by JDM-EJ1 at 10:28 PM 12/27/2006
Old Dec 27, 2006 | 09:23 PM
Suck my DX's Avatar
Default Re: does anyone know how too..... (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
You'll want to use washers on the back bolt on each side of your hood HINGES. </TD></TR></TABLE>
Old Dec 27, 2006 | 09:26 PM
Harryflores's Avatar
Default Re: does anyone know how too..... (Suck my DX)
that is so 2 years ago !
Old Dec 27, 2006 | 09:28 PM
Suck my DX's Avatar
Default Re: does anyone know how too..... (Harryflores)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Harryflores &raquo;</TD></TR><TR><TD CLASS="quote">that is so 2 years ago ! </TD></TR></TABLE>
hes doing it for the function not the look...its not your car so why you give a **** anyways
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">You'll want to use washers on the back bolt on each side of your hood HINGES. </TD></TR></TABLE>
Thanks!
Refer to my original comment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">**** off. The guy asked a legitimate questions, if you have a problem with what he wants to do with HIS car than you can leave. Thanks for your understanding.</TD></TR></TABLE>
Old Dec 27, 2006 | 09:32 PM
Suck my DX's Avatar
np...lol didnt want the guy to end up putting washers on his hood latch
Old Dec 27, 2006 | 09:33 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">np...lol didnt want the guy to end up putting washers on his hood latch </TD></TR></TABLE>
Haha, good call. Got my words mixed up!
Old Dec 27, 2006 | 09:45 PM
Suck my DX's Avatar
how big of a difference will the hood mod make for underhood temps? has anyone ever tested this...i got 3 mph in the 1/4 by doing the TB/IACV coolant bypass mod...sometimes i notice the engine temps raise a bit when i beat on it and id like to get the engine temps down a bit more...hopefully get sum more mph out of it
Old Dec 27, 2006 | 09:50 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">how big of a difference will the hood mod make for underhood temps? has anyone ever tested this...i got 3 mph in the 1/4 by doing the TB/IACV coolant bypass mod...sometimes i notice the engine temps raise a bit when i beat on it and id like to get the engine temps down a bit more...hopefully get sum more mph out of it</TD></TR></TABLE>
I believe the 'hood prop' is meant specifically for cars that run individual throttle bodies.
Old Dec 27, 2006 | 09:55 PM
Suck my DX's Avatar
oh yeah...hmmm well i guess i gotta try it out next time i tke it to the track
Old Dec 27, 2006 | 09:56 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah...hmmm well i guess i gotta try it out next time i tke it to the track</TD></TR></TABLE>
Logically speaking, it makes the most sense for propping your hood in the rear if you run ITB's. If you're running just a standard intake, you could put a vent in your hood directly infront of the intake filter.
ridin98civic's Avatar
i saw a thread where a guy used an infrared(i think) heat sensor to read the engine temp before and after this mod, and it was 10-15 degrees cooler (dont quote me i couldnt find the thread this is from memory.)
Old Dec 27, 2006 | 10:17 PM
my_slow_civic's Avatar
Logically speaking, it makes the most sense for propping your hood in the rear if you run ITB's. If you're running just a standard intake, you could put a vent in your hood directly infront of the intake filter.</TD></TR></TABLE>
I raised mine, because my damn supercharger creates some insane heat, and I can use all the help I can get by vacating heat pockets, and creating a better flow of air.
Old Dec 27, 2006 | 10:22 PM
Suck my DX's Avatar
Default Re: does anyone know how too..... (ridin98civic)
well if i do the mod it wouldnt be for induction it would be more along the lines of engine cooling...it would be a track only think if the difference is minimal since i dont much care for the look of the mod...but if it really drops underhood temps by 10-15 degrees ima have to do it...i already made a pretty neat little ram air dealie with a spare headlight i had
Old Dec 27, 2006 | 10:44 PM
JDM-EJ1's Avatar
Default Re: does anyone know how too..... (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic &raquo;</TD></TR><TR><TD CLASS="quote">I raised mine, because my damn supercharger creates some insane heat, and I can use all the help I can get by vacating heat pockets, and creating a better flow of air.</TD></TR></TABLE>
Never thought of this one. I can see the practicality in this as well.
Old Dec 30, 2006 | 10:32 PM
Modified by JDM-EJ1 at 10:28 PM 12/27/2006</TD></TR></TABLE>
Excuse me fuckass. I misread his question, I thought he asked how to open the hood. I apologize to the OP. Thanks for your understanding.
Shingo
Dec 10, 2006 10:51 AM
b16a2coupe
29
Jul 30, 2006 07:46 PM
SubTitle
Mar 12, 2006 06:10 AM
91EXRMANUAL
Dec 16, 2004 05:27 AM
weakGOODJunKieS.com
Nov 4, 2003 06:04 PM
