headers heating up??????????
Old Dec 27, 2006 | 04:04 PM
iheartamy's Avatar
Default headers heating up??????????
ok headers are heating up red and the temp of the car is still normal
is it fuel problem?
exhaust?
Old Dec 27, 2006 | 04:07 PM
philosofy1's Avatar
Default Re: headers heating up?????????? (iheartamy)
no, this is perfectly normal.
Old Dec 27, 2006 | 05:32 PM
iheartamy's Avatar
Default Re: headers heating up?????????? (philosofy1)
bump for some help
Old Dec 27, 2006 | 05:34 PM
9200RPM's Avatar
are they red while is the car is sittin there or after it was ran hard?
Old Dec 27, 2006 | 05:49 PM
JDM-97CX's Avatar
Default Re: headers heating up?????????? (TurboB16aEG)
They shouldn't get cherry red unless you are running a lot of fuel through the motor.
If you do not have fuel adding mods you have a fuel delivery issue.
If you do have fuel mods and you don't need them take them off.
Old Dec 27, 2006 | 05:50 PM
9200RPM's Avatar
Default Re: headers heating up?????????? (JDM-97CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX &raquo;</TD></TR><TR><TD CLASS="quote">They shouldn't get cherry red unless you are running a lot of fuel through the motor.
If you do have fuel mods and you don't need them take them off.</TD></TR></TABLE>
Old Dec 27, 2006 | 06:27 PM
iheartamy's Avatar
well i was thinking about getting a b&m fuel pressure gauge, because i did the h2293civic swap no mods really just usually bolt ons. but some people told me it has to do with the cat converter. my resenator is bad could that affect anything?
Old Dec 27, 2006 | 06:30 PM
deadline's Avatar
re-do the exhaust piping at a shop
Old Dec 27, 2006 | 06:35 PM
9200RPM's Avatar
you shouldnt need an adjustable fpr....if you are hell bent on getting one dont get the b&m they will eff up....save your money toward a tune...you would be surpsrised how much that would help..
iheartamy's Avatar
Default Re: (deadline)
yeah i was thinking that, but i also forgot to mention i have a walbro 255 fuel pump
Old Dec 27, 2006 | 06:37 PM
9200RPM's Avatar
Default Re: (iheartamy)
the stock fpr should be sufficient for what you are doing....but like i said if you are determined to get one DO NOT get a b&m....
Old Dec 27, 2006 | 06:53 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadline &raquo;</TD></TR><TR><TD CLASS="quote">re-do the exhaust piping at a shop</TD></TR></TABLE>
That has nothing to do with the manifold heating up.
Is it getting cherry red all the time or does it just get a hint of red after you beat the **** out of it?
Old Dec 27, 2006 | 06:56 PM
9200RPM's Avatar
Default Re: (JDM-97CX)
if the cat is backing up wouldnt get a little red?
Old Dec 27, 2006 | 06:59 PM
JDM-97CX's Avatar
Default Re: (TurboB16aEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">if the cat is backing up wouldnt get a little red?</TD></TR></TABLE>
If the cat was clogged it wouldn't be able to get red, the car wouldn't be able to run. Or it would push out an exhaust gasket, and run like ****. Not to mention the check engine light and one hell of a fuel problem.
Old Dec 27, 2006 | 07:01 PM
9200RPM's Avatar
yeah that makes sense....
Old Dec 27, 2006 | 07:31 PM
iheartamy's Avatar
well thanks for all the comments guys, i really do appreciate it!
raphael
Aug 17, 2006 03:44 AM
rewerbcrx
Oct 19, 2005 08:31 AM
SiShane
Jun 8, 2004 02:56 PM
mrcrimane
Aug 9, 2003 11:43 AM
