b16a swap getting code 4 cps. please help..
Old Dec 27, 2006 | 03:45 PM
gsxr1k05's Avatar
Default b16a swap getting code 4 cps. please help..
car starts and runs, but it idles at 2k, and i get code 4 and 21. i redid the wiring from the vtec solenoid and i have the cps wires right or the car would not be able to start. i know this cause i switched them at the dizzy and it would crank but not start. any one have any ideas??>
Old Dec 27, 2006 | 07:17 PM
gsxr1k05's Avatar
15 poeple looked at this and dont know?? WTF
Old Dec 27, 2006 | 08:37 PM
joshfish79's Avatar
Default Re: b16a swap getting code 4 cps. please help.. (gsxr1k05)
i dont know off hand what codes those are but a high idle can be from an intake gasket leak or another form of vacuum leak. try spraying some brake clean around intake gasket and see if idle comes down.
Old Dec 28, 2006 | 05:30 AM
gsxr1k05's Avatar
well, the codes are listed in the OP. i think is the eacv not working. when i bought the crx that the swap came out of it ran fine with no CEL at all. so i know it must have something to do with the wiring.. that case, i guess i answered my own post.. sorry to post unncessarily on the forum.
Old Dec 28, 2006 | 06:02 AM
Loserkidwac's Avatar
Default Re: (gsxr1k05)
well grab a manual and follow the tests for each code...we had a cps code in my gf lil bros 92 Teg, swapped in 3 different dizzys (2 wire for MSD ext coils and one Stock) ran new wires straight from the ECU to dizzy and then finally swapped in new ECU and that was it
HTH...matt
Old Dec 28, 2006 | 08:06 AM
Tippyman's Avatar
Default Re: (Loserkidwac)
This should help you out alot: https://honda-tech.com/zerothread?id=468260
Bagged_em1
Oct 31, 2016 06:09 PM
super jdm yo
Apr 12, 2012 11:04 AM
Nathan_volcom
Dec 4, 2011 03:01 PM
redrex91
Jul 28, 2003 03:39 AM
TheHatchHog
16
May 15, 2003 11:26 AM
