Which OE exhaust pieces to use with a B18B + 92 CX?
Old May 13, 2002 | 10:44 AM
Willard's Avatar
Default Which OE exhaust pieces to use with a B18B + 92 CX?
I will be installing a B18B this weekend and 'should' get the stock header/cat with the swap.
Questions:
-will a ITR header/cat work in the place of the stock B18B stuff?
-will a Civic SI (92-95) "B" pipe work with the ITR cat and stock muffler?
Thanks for any help....
William
Old May 13, 2002 | 11:49 AM
Jonathan_ED3's Avatar
Default Re: Which OE exhaust pieces to use with a B18B + 92 CX? (Willard)
i have a '92 CX w/b18b....5zigen catback exhaust. 90-93 Integra Catalytic Converter..and stock b18b bpipe/exhaust manifold. everything bolted together perfectly.
edit: i don't know about the ITR header/bpipe, but i do know the 94+ Integra Cats are about 3-4" too long to bolt to a Civic catback exhaust with the STOCK B18b bpipe section. i finally figured out a 90-93 LS/GS/RS b18a cat was the perfect fit. so unless the ITR bpipe is 3-4" shorter than the stock b18b, then you're gonna have some issues.
[Modified by hot_EF, 8:52 PM 5/13/2002]
preetyboi06
Aug 20, 2009 08:35 AM
STN_Pat
Apr 5, 2004 10:35 AM
Race Egr
Mar 8, 2004 07:06 AM
g_man80
Jun 16, 2002 10:13 AM
