rebilding calipers??
Old Dec 27, 2006 | 02:46 PM
SOHC_me's Avatar
Default rebilding calipers??
OK, so i bought some prelude vtec calipers off a 97, i want to rebiuld them, whats the cost going to be, and what parts do i have to replace? is it hard to rebiuld them?
Old Dec 27, 2006 | 02:50 PM
Doostur's Avatar
Default Re: rebilding calipers?? (SOHC_me)
search is was covered not too long ago.
Old Dec 27, 2006 | 02:54 PM
PrinceAli132's Avatar
Honda sells a rebuild kit and it will come with everything you need. Heres how the rebuild kit looks, for ITR calipers;
I also went ahead and replaced all related bolts, pins, and retainers;
I replaced just about everything and it cost me a bit more than $200 but if you just by the rebuild kit it will be a lot cheeper.
So far I have disassembled the front calipers which was really easy and i don't think it will be that hard to re-assemble (I haven't done it yet). But check this link out which explains and shows you everything.
http://www.performanceforum.co....html
Ali
Modified by PrinceAli132 at 7:14 PM 12/27/2006
Old Dec 27, 2006 | 03:00 PM
crxgator's Avatar
does anyone trust the rebuilt calipers you get from autozone? i mean they are only like 50 bucks a piece...
Old Dec 27, 2006 | 03:06 PM
SOHC_me's Avatar
Default Re: rebilding calipers?? (crxgator)
just searched some more and found all the info i needed, sorry for the useless post. but how much do you think the rebiuld kit cost, i would need it for all 4, front and rear?
Old Dec 27, 2006 | 03:09 PM
SOHC_me's Avatar
Default Re: rebilding calipers?? (PrinceAli132)
do the rebuild kits also come with new pistions? or just all the seals
Old Dec 27, 2006 | 03:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_me &raquo;</TD></TR><TR><TD CLASS="quote">do the rebuild kits also come with new pistions? or just all the seals</TD></TR></TABLE>
Did you even look at my first post.
This is what the rebuild kit comes with
No pistons
The fronts were roughly $20 a side. I believe the rears are around the same price.
Ali
Old Dec 27, 2006 | 03:46 PM
jdm_DC2R's Avatar
The ones at PartSource here in Ontario (autozone in US) , they are rebuild, with new seals, etc and come semi-loaded, meaning they come with the caliper bracket even, all the nuts/bolts, washers, pins, etc, everything included and ready to install. You might ask if these are any good?? well yes, cause they are original honda calipers, just redone and made to look like new. Price is around $110CDN for one ITR caliper. I think this is a much easier and better way to do it, rather than buyin all the separate peices from honda and doint it yourself.
Old Dec 27, 2006 | 05:49 PM
an2ny888's Avatar
Default Re: (jdm_DC2R)
rebuilding a caliper is a straight forward job, the most difficult part is installing the rubber boot on to the piston without tearing it
forbiddenera
Suspension & Brakes
Oct 3, 2017 07:06 PM
trianglegreg
Apr 18, 2007 11:48 AM
fastbrakes
Dec 25, 2001 12:27 PM
KekeK-18
Oct 23, 2001 09:34 AM
killerTeg
Sep 14, 2001 08:30 AM
