Highest SC50 (50-Trim) numbers on PUMP GAS?
Old Dec 27, 2006 | 10:39 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Highest SC50 (50-Trim) numbers on PUMP GAS?
How far has the SC50 been pushed on pump gas? And also, how much boost was run to hit those peak numbers?
This also applies to the Garrett 50-trim as well.
The only dynos I've seen are from my buddy's built B16, making ~334whp at 16-17 lbs, Mase-tuned.
I'm hoping for 375whp on pump gas. Is it possible with the SC50? I have the .48 a/r on a GSR though.
Old Dec 27, 2006 | 10:45 AM
SL0WEGG's Avatar
Default Re: Highest SC50 (50-Trim) numbers on PUMP GAS? (boostincoupe)
nevaR!
Old Dec 27, 2006 | 11:25 AM
Default Re: Highest SC50 (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">nevaR! </TD></TR></TABLE>
Bastage.
I think around 360-370whp would put a smile on my face...for next season.
Old Dec 27, 2006 | 11:26 AM
tony1's Avatar
Default Re: Highest SC50 (boostincoupe)
that's a lot of **** to fit through a .48 housing!
Old Dec 27, 2006 | 11:30 AM
Default Re: Highest SC50 (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">that's a lot of **** to fit through a .48 housing!</TD></TR></TABLE>
Platinum00 made 427whp on race gas with the same turbo on a d16y8!
I think he made 404whp on pump, but I'll have to search and check.
Old Dec 27, 2006 | 11:44 AM
joppe's Avatar
Dynapack numbers?
Old Dec 27, 2006 | 12:05 PM
delslo93's Avatar
Default Re: (joppe)
Not to thread jack but I have an ITS 50 trim (.63 a/r) that will be going on my build b16. Think I can make 400 with it with pump gas??
Old Dec 27, 2006 | 12:28 PM
Chip's Avatar
Default Re: (delslo93)
Somebody on the DSM boards made over 500 AWHP on a 50-trim. That was at like 30 psi though and IIRC under 10 degrees of timing
Old Dec 27, 2006 | 01:33 PM
Default Re: (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">Somebody on the DSM boards made over 500 AWHP on a 50-trim. That was at like 30 psi though and IIRC under 10 degrees of timing </TD></TR></TABLE>
Probably on race gas though, right? That's what I'm trying to stay away from. I want to see what my car can do on straight BP 92 octane pump gas reliably.
Old Dec 27, 2006 | 01:43 PM
spoolin turbo s's Avatar
Default Re: (boostincoupe)
a guy in pa made 361 or something like that on .48 50 trim on pump gas on 1.8t VW stock motor from head to oilpan
actually he's been on here some as he had a teg then it got stolen like a week after evans tuned it nebulight is his name
Old Dec 27, 2006 | 01:47 PM
Bailhatch's Avatar
this is true
Old Dec 27, 2006 | 02:15 PM
tony1's Avatar
How high are you planning on reving the motor?
Old Dec 27, 2006 | 02:57 PM
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">
Probably on race gas though, right? That's what I'm trying to stay away from. I want to see what my car can do on straight BP 92 octane pump gas reliably. </TD></TR></TABLE>
Nope, pump gas. Look him up on DSMtuners, dregsx was his user name.
Old Dec 27, 2006 | 03:06 PM
nowtype's Avatar
Default Re: (Chip)
I don't see 375ish being that much of a stretch as long as you are doing other things to minimize reversion. An EL manifold and 3"+ exhaust with little to no restriction are musts. The little things like making sure the dumptube is routed away from the air filter and things of that nature will also help. Most likely you are going to find yourself at around 350ish whp but with a significant increase in midrange torque compared to a .63 housing.
Old Dec 27, 2006 | 03:50 PM
blundar's Avatar
9:1 built LS/Vtec, stock b16 head, GSR cams, .63A/R SC50, 93 octane pump, ~360whp on 18-19ish psi on a MUSTANG dyno known to read 15+% lower than hater-tech compatible dynojets. I don't have the dyno sheets for these runs, but I might be able to get them tomorrow while at the dyno.
The same car made 280whp on the Mustang and 341 whp on a dynojet (no change in tuning or setup, just dyno) as a 9:1 compression rod/piston LS non-vtec with the same turbo. I have the dyno sheets for this one if anyone is interested to see.
Car belonged to a guy named Roger from Dayton who sold it to his neighbor Benji. I tuned both setups. It's still alive and doing great.
Old Dec 27, 2006 | 03:57 PM
tony1's Avatar
Default Re: (blundar)
How much do you think the .48 housing will choke it up at those power levels? I had a real bad experience with a .48 housing on a GT30R car. So bad that going from a 2.25" exhaust system to an open 3" downpipe made 2hp! The restriction was at the housing, so freeing it up after that didn't do anything. This was at 300whp around 15psi.
Old Dec 27, 2006 | 05:40 PM
Boostfed's Avatar
New User
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">How much do you think the .48 housing will choke it up at those power levels? I had a real bad experience with a .48 housing on a GT30R car. So bad that going from a 2.25" exhaust system to an open 3" downpipe made 2hp! The restriction was at the housing, so freeing it up after that didn't do anything. This was at 300whp around 15psi.</TD></TR></TABLE>
Prolly needed a good tuner! J/K Tony
Old Dec 27, 2006 | 05:45 PM
tony1's Avatar
Default Re: (Boostfed.com)
That's what i figured, but i couldn't find anybody good, they were all busy.
Old Dec 27, 2006 | 09:22 PM
blundar's Avatar
oh ****... didn't see it was a .48
sell it to someone with a stock LS. Perfect
Old Dec 27, 2006 | 10:20 PM
SL0WEGG's Avatar
Default Re: (nowtype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype &raquo;</TD></TR><TR><TD CLASS="quote">I don't see 375ish being that much of a stretch as long as you are doing other things to minimize reversion. An EL manifold and 3"+ exhaust with little to no restriction are musts. The little things like making sure the dumptube is routed away from the air filter and things of that nature will also help. Most likely you are going to find yourself at around 350ish whp but with a significant increase in midrange torque compared to a .63 housing.</TD></TR></TABLE>
Well since he hasnt answered, ill answer for him. He's using a Ramhorn manifold, 3" dp all the way to the muffler, dump goes out the front bumper
Old Dec 28, 2006 | 06:24 AM
Default Re: (boostedej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedej1 &raquo;</TD></TR><TR><TD CLASS="quote">Well since he hasnt answered, ill answer for him. He's using a Ramhorn manifold, 3" dp all the way to the muffler, dump goes out the front bumper </TD></TR></TABLE>
&lt;-- Hungover
Spoolin' ramhorn manifold, 3" DP, 3" Magnaflow cat, 3" KTeller with 18" resonator, to a 3" Magnaflow straight-through. And yes, the infamous dumptube out the front bumper
So I think I've got the flow part of things covered, mostly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">How high are you planning on reving the motor? </TD></TR></TABLE>
Roughly 8000-8200rpm, bone stock GSR head and I don't want to unnecessarily push it. It will either be mated to a 81.5mm GSR block, 81.5mm LS block, or a 84mm sleeved GSR if I can get it before it sells locally. In which case I'll step up to a SC6152E.
Old Dec 28, 2006 | 07:47 AM
platinum00's Avatar
D16Y8.
~315whp on PUMP @ 16-18psi
~427whp on C16 @ 26-27psi
Should be able to see higher numbers on a B series on PUMP.
platinum.
Old Dec 28, 2006 | 07:54 AM
tony1's Avatar
Default Re: Highest SC50 (platinum00)
The small exhaust housing is going to have really high backpressure at those power levels and limit the power potential on pump gas because of it. The knock limit on the motor goes to **** with really high backpressure because of exhaust contamination. It's a simple fix, sell the .48 housing and buy a .63, they're not expensive.
Old Dec 28, 2006 | 08:00 AM
platinum00's Avatar
....And experiance more lag. If the .48 will meet your goals use the .48
platinum.
Old Dec 28, 2006 | 08:07 AM
tony1's Avatar
And increase the chance of blowing your motor up because of a bad tank of gas. Go for it!
