will EG springs fit EF?
Old Dec 27, 2006 | 09:12 AM
DmcL's Avatar
Default will EG springs fit EF?
need to know because someone is breaking an EG with lowered springs.
Old Dec 27, 2006 | 09:15 AM
KingDanOne's Avatar
Default Re: will EG springs fit EF? (DmcL)
nope..
Old Dec 27, 2006 | 09:18 AM
DmcL's Avatar
poo
Old Dec 27, 2006 | 09:22 AM
Loserkidwac's Avatar
Default Re: will EG springs fit EF? (KingDanOne)
Well we used my CRX rear shocks on a 95 Integra LS and the spring and shocks were identical, different part numbers but physically identical...for the front I can't confirm, from what I have heard the front shocks are thicker but I can only imagine the springs are similar...
Old Dec 27, 2006 | 09:23 AM
N_A_is_best's Avatar
Default Re: will EG springs fit EF? (Loserkidwac)
i dont see y they wouldnt work
Old Dec 27, 2006 | 09:39 AM
89efDUSTY's Avatar
Dont think so also looks at dimensions...http://image.bizrate.com/resize?sq=1...804&mid=123044 vs. http://www.heeltoeauto.com/fil....hope it helps
Old Dec 27, 2006 | 09:43 AM
VtecSyndrome's Avatar
Default Re: will EG springs fit EF? (N_A_is_best)
The spring rates are different, the EG front springs are longer than the EFs and they just stright up will not work (correctly that is). I too have EG rear tokicos on my rex but when comparing the fronts you can plainly see the diffferences in size and suspension travel. Now if you are trying to use EG coilovers (sleeve kit only) on EF suspension then that will work. It wil l be a stiffer spring rate but I personally like it that way, that's why I have DC2 skunk2 coilovers on my '89 REX. I just had to buy the correct EF Tokico 5-way for the front.
Old Dec 27, 2006 | 03:15 PM
RSZero1's Avatar
Default Re: will EG springs fit EF? (VtecSyndrome)
The inner and outter diameter is the same, but it is a taller spring. You would have to cut it to make it fit, or if it was a really low spring type you may get it to work. It just may not drop it as much as you think.
Old Dec 28, 2006 | 01:11 PM
Private-Tune's Avatar
Default Re: will EG springs fit EF? (RSZero1)
it will work if your looking for that 4x4 look. Eg springs are too long
Old Jan 26, 2007 | 08:49 PM
SilentHatch's Avatar
What about Ek 99-00 Si springs? Will they fit?
Old Jan 26, 2007 | 10:37 PM
superhatchbackbros's Avatar
ek didnt fit. i just tried them on my 89 civic hatch and they were too long and made my car 4x4.
Old Jan 26, 2007 | 11:03 PM
Hamstr323's Avatar
Default Re: (superhatchbackbros)
http://www.ef-honda.com/ben/EFhybridsus.php
Old Jul 18, 2007 | 05:39 PM
urkcrx's Avatar
Had to resurrect after my experience. Will they fit? Yes. . .
Will they look like crap? Yes. . .
I didn't heed the advice of the board and proceeded.
Pic #1 is with stock '89 CRX DX springs with 205/50/16 tires
Pic #2 is with '95 EG DX springs with 205/40/16 tires.
Yes, the tires are 1.6" shorter but its still a HUGE gap ~ 4.5" from top of tire to bottom of wheel well.
And, yes, new springs are on the way. . .
JScott3d
Apr 15, 2009 12:15 PM
exz0n-.-
11
Oct 28, 2008 12:30 PM
em Dot
Jul 28, 2004 04:47 PM
Jun 2, 2003 09:50 AM
