Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Tranny Noise!
Old Dec 27, 2006 | 06:41 AM
roxyhonda's Avatar
Default Tranny Noise!
Yep, it seems that my 01 civic is making a tranny noise, car has 980000 miles and I heard it could be the throw bearing or a bearing of some sort, anyone else have this problem? Thanks!
Old Dec 27, 2006 | 07:00 AM
Miracle's Avatar
Default Re: Tranny Noise! (roxyhonda)
When does it make the noise? Clutch engaged/disengaged? Crusing/accelerating/decelerating/stopped? Gear engaged?
Old Dec 27, 2006 | 01:21 PM
roxyhonda's Avatar
Default Re: Tranny Noise! (Miracle)
makes noise disengaged, and when I press on the clutch, it stops, but could hear it slightly when in 5th gear, I may pull the tranny, and inspect the tranny. It is very obvious pulling in first gear, loud vibrant RRRRrrrrrrrrr sounds awful. My wife babied this car!
Old Dec 27, 2006 | 01:50 PM
Miracle's Avatar
That sounds like the input shaft bearing on the transmission itself. The transaxle will need to be pulled from the car, and the bearing needs to be replaced.
Here is a little reading material for you on manual trans issues on the 7th Gen Civic (EM2)...
http://www.civicforums.com/for....html
Old Dec 28, 2006 | 07:24 AM
roxyhonda's Avatar
This is very helpful, thank you
Old Dec 30, 2006 | 04:42 PM
sicem01's Avatar
i am actually fixing that problem right now. Its the pilot bearings for the trans shaft. theyre busted and letting the shaft wobble and make a weird almost grinding noise. Tour best bet is to replace the tranny, recommended one from a junkyard cuz it'll cost an arm and a leg to get it fixed at a trans shop. But fix it soon cuz it can throw ur shaft into the gears before too long
Old Jan 2, 2007 | 10:22 PM
Bizon's Avatar
thats a lot of miles, son
Matt (SG)
Jun 5, 2008 05:06 PM
CPR
Dec 14, 2005 10:26 PM
LvN
30
Sep 20, 2005 07:49 PM
GSRacer1
May 31, 2004 11:33 PM
ProJectCvic
May 26, 2004 02:23 PM
