Full coilovers...
Old May 13, 2002 | 08:47 AM
Superhatch's Avatar
Default Full coilovers...
Im going to be on the road the whole month of june...which means mega$$$$ so Im going to buy a full coil-over suspension when I get back. I was looking for some opinions on good brands etc... Im looking to spend around 12xx-14xx. Thanks in advance.
-Jake
Old May 13, 2002 | 08:57 AM
Superhatch's Avatar
Default Re: Full coilovers... (SuperHatch)
Im looking at Tein's right now...just went to their website and they look nice and cost a little over a grand..not to bad. Other ideas?
-Jake
Old May 13, 2002 | 12:23 PM
B16CRX's Avatar
Zeal
Tanabe
Progress
I know there are more out there, can't think of them right now though.
Old May 13, 2002 | 12:27 PM
EP3_05's Avatar
Progress
Tein
H&R
JIC magic
Those are a few I know off the top of my head. They are all in your price range and all are excellent systems.
Old May 13, 2002 | 01:36 PM
keithv's Avatar
i am 99% sure you will need type r/88 crx si rear LCAs to use the tein coilovers. so its just one more thing to think about.
Old May 13, 2002 | 02:32 PM
Denny317's Avatar
Get the Tein's or Zeal because I've heard good things about them both.
Old May 13, 2002 | 03:07 PM
HumanResource's Avatar
Progress
Are you talking FULLY ADJUSTABLE assemmblies?
Ride height, ride (both bump and rebound) all adjustable?
You'd be better off going with the classic GC+ KONI combo with the $$$ you save get some adj. pillow's.
Most kits out there are watered down for the street-
Only advantage of getting full assembly would be the shortened shock.
Old May 13, 2002 | 03:40 PM
trav's Avatar
i like the teins ! i just got a set of the flex set for my 98 dx hatch !
Old May 13, 2002 | 03:52 PM
bryant's Avatar
Default Re: Full coilovers... (breaka_1_9)
Make that 100% sure.
Old May 13, 2002 | 04:42 PM
ivanED9's Avatar
Default Re: Full coilovers... (CR-X)
I am gettin the H&R Full Threaded coilovers shortly, and from those who have em, they say they love em. If you want alternatives: Tein HA's, Zeal B2, custom spring rate Ground Controls on Koni Yellow's, or Progress
Old May 13, 2002 | 07:41 PM
Bnjmn's Avatar
Default Re: Full coilovers... (Chris90STD)
I read a big article a while back at how coil overs are actually a pain unless your have a 4 wheel scale so you can set the loads and that a good shock/spring combo was better than coil overs. Anyone have any thoughts on this?
Thanks
Ben
Old May 13, 2002 | 08:32 PM
kranked91dx's Avatar
heard really good thing about Tein also about progress,
look carefully the specs and choose the best for your application.
Old May 13, 2002 | 08:54 PM
Superhatch's Avatar
Default Re: Full coilovers... (Bnjmn)
. Anyone have any thoughts on this?Thanks
Ben
Actually, I wouldnt ever go with just a coil over and seperate shock..for the exact reason you stated & you dont get the performance of a full coil over suspension. The only reason Im going with a full coil over is that I want the best package I can get for my car. A shop near me has scales, so Ill be covered there.
-Jake
Old May 13, 2002 | 09:05 PM
hondacivic4g's Avatar
Go here and read about Progress group coil-overs they claim to manage 1.0 G cornering from their 89 hatch, the new Honda Tuner has the Hatch on the cover.I thought it was a pretty impressive car and the coil-over set up, is right around $1400. That's what I'm looking at going with, check it out http://www.progressauto.com
Old May 13, 2002 | 09:12 PM
Steve91's Avatar
I would only go with a kit that actually uses a shorter shock like Progress or Koni. That way you can lower the car without loosing shock travel.
Old May 13, 2002 | 10:25 PM
ED8DX's Avatar
Default Re: Full coilovers... (Steve91)
H&R full coilover. Shortend shock body and matched springs and it rides like heaven.
Mr Ohms
Suspension & Brakes
Jan 7, 2013 09:26 AM
xx1NT3G-R4xx
Suspension & Brakes
12
May 20, 2007 08:31 PM
sydegsr
Jan 31, 2006 02:01 PM
.brian.
Nov 17, 2004 03:32 PM
-Darren-
Dec 6, 2002 12:14 PM
