Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2002 Acura MDX - radio serial number format
Old Dec 26, 2006 | 01:39 PM
choman's Avatar
Default 2002 Acura MDX - radio serial number format
Hi guys. Over Christmas my daughter ran down my battery listening to the radio and, of course, the anti-theft system for the radio kicked in. I purchased this vehicle pre-owned in the summer and am unable to find the code to unlock in the glove compartment. I have searched all over the net and understand that my only option now is to get the serial number and take it to a local dealer for them to get the unlock code for me. I was just wondering though, I found a number on a white sticker under the cap covering the fuses in the engine compartment that looks like it may be the serial number. The sticker is about an inch and a half long, and a half inch tall. It has a four digit number on top of a number formated like this B########B. I don't want to put the actual numbers in just in case. Would this possibly be the serial? It looks like the stickers were placed inside this cover from somewhere else since they are pealling off a bit.
Old Dec 28, 2006 | 04:13 PM
APEX CRX's Avatar
Default Re: 2002 Acura MDX - radio serial number format (choman)
Radio code would be 5 digits, PM the possible serial # and I'll check to see if it is a correct serial. The serial # sticker is usually placed on the inside of the glovebox by the dealer so inside the fuse cover sounds wrong
Old Dec 28, 2006 | 07:15 PM
choman's Avatar
Default Re: 2002 Acura MDX - radio serial number format (APEX CRX) !!!!EDITED!!!!
Thanks for your response. The number that I *thought* was the serial is - B20638682B.
above this number is a 4 digit number - 2247. I found this on one of the two stickers inside the fuse box. The other sticker has the number 30011613.
UPON FURTHER INSPECTION in the glove compartment, on the left outer surface of the compartment when opened, there is also a sticker that says 30011613. As this is the same number as the previously mentioned second sticker I found inside the fuse cover box, I am inclined now to think this is the radio serial number.
Modified by choman at 6:01 AM 12/29/2006
Old Dec 29, 2006 | 11:56 AM
APEX CRX's Avatar
Default Re: 2002 Acura MDX - radio serial number format (APEX CRX) !!!!EDITED!!!! (choman)
PM'D you the possible radio code
Lsinger
Mar 18, 2017 01:54 PM
sleepyman2015
Honda Civic (2001 - 2005)
Jun 29, 2015 07:05 PM
dohc_profile
Aug 4, 2008 11:01 AM
pete griffen
Nov 1, 2005 06:44 AM
ismkv8s
Audio / Security / Video
Dec 29, 2002 11:26 AM
