Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2 TL Questions
Old Dec 26, 2006 | 11:25 AM
ah2k6's Avatar
Default 2 TL Questions
1. If Honda replaces the tranny in a TL, is it the newer design, or is it the same transmission that's almost guaranteed to crap out?
2. Do TL's have to run on premium fuel, like the RL's?
Old Dec 26, 2006 | 03:46 PM
YeuEmMaiMai's Avatar
Default Re: 2 TL Questions (ah2k6)
1. Supposidly the repalcements after Feb '05 are the fixed units
2. Yes you have to use 91 or higher octane
Old Dec 27, 2006 | 11:02 AM
Shaun's Avatar
damn ive been running 89..
Old Dec 29, 2006 | 09:07 AM
mikelax125's Avatar
* B A N N E D *
i work for acura and watch these trannys come in and out all day. we "claim" the problem is fixed, but i see mor people comeing back every day with this problem,m after the swap. but there is a new and fixed solution for the issue out nowso head down and ask about it. and in ALL acura cars u should run 91 or higher. except the rsx or integras.
Old Dec 31, 2006 | 10:41 AM
killerX's Avatar
Default Re: 2 TL Questions (mikelax125)
i also work for ACURA the second recon units are coming back junk, good luck an good night with your TL trany .
killerX's Avatar
i also work for ACURA the second recon units are coming back junk, good luck an good night with your TL trany .its almost a hit or miss when you get the new trany
Old Jan 1, 2007 | 12:45 AM
ah2k6's Avatar
Default Re: 2 TL Questions (killerX)
Great.
I like the TL, but I don't think I'm willing to put up with that kinda crap. If they just offered a manual for that generation of TL's, I'd have no problems.
Old Jan 1, 2007 | 01:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ah2k6 &raquo;</TD></TR><TR><TD CLASS="quote">Great.
GO check this site out......acura-tl.com according to the members over there the newer repalcements seem to be holding up fairly well. There is a TSB that indicates that it a certain part of the trans was damaged during shipment, do not install the unit (some peice breaks off of the VSS and falls into the trans).........
Old Jan 1, 2007 | 01:57 PM
ah2k6's Avatar
Default Re: 2 TL Questions (YeuEmMaiMai)
I'll check that out, thanks.
If the transmission goes a second time, what are the chances that Honda will do a goodwill repair on it?
Old Jan 5, 2007 | 12:48 PM
u n v kenny's Avatar
I believe when they give you a new tranny that they're 3yr/36k warranty. NOT entirely sure though.
lanceh
Nov 1, 2008 05:13 PM
palmerrules
Acura TL, RL & ZDX
Jul 20, 2004 06:41 AM
R0902
Aug 1, 2002 04:17 PM
Black SVT
Nov 13, 2001 03:20 PM
