88 crx hf.. quick question
Old Dec 26, 2006 | 10:44 AM
Drew17th's Avatar
Default 88 crx hf.. quick question
is it dpfi or mpfi???
thx
Old Dec 26, 2006 | 10:49 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: 88 crx hf.. quick question (Drew17th)
MPFI.
Old Dec 26, 2006 | 10:59 AM
Drew17th's Avatar
so it is mpfi??? does ot have rear disk??? what about a tach??? thx
Old Dec 26, 2006 | 11:01 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th &raquo;</TD></TR><TR><TD CLASS="quote">so it is mpfi??? does ot have rear disk??? what about a tach??? thx </TD></TR></TABLE>
Rear disk not stock tach yes. came with a real low redline and a shift light, made for gas milage, not speed. Comes on at like 2300 or something lol.
Old Dec 26, 2006 | 11:03 AM
Drew17th's Avatar
i had a 91 crx si lol and then a del sol and i can get a killer deal on a clean 88 hf... just trying to see some things i would have to do lol....
Old Dec 26, 2006 | 11:04 AM
Ass$nyper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th &raquo;</TD></TR><TR><TD CLASS="quote">i had a 91 crx si lol and then a del sol and i can get a killer deal on a clean 88 hf... just trying to see some things i would have to do lol.... </TD></TR></TABLE>
If it's that killer a deal get it no matter and resale.
Old Dec 26, 2006 | 11:05 AM
Loserkidwac's Avatar
Default Re: 88 crx hf.. quick question (Capt. Blonde Beard)
88 Hf is the lightest of the CRXs, great car to turn into a project
Old Dec 26, 2006 | 11:07 AM
Drew17th's Avatar
thats true lol... if i keep it tho i will mos def put rear disk in and hmm... is the gages interchangeable wit like a 91??? or no??
Old Dec 26, 2006 | 11:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew17th &raquo;</TD></TR><TR><TD CLASS="quote">thats true lol... if i keep it tho i will mos def put rear disk in and hmm... is the gages interchangeable wit like a 91??? or no??</TD></TR></TABLE>
Depedning on your overal plans for the car, rear dics may just be adding weight, they only do something like 30% of the stopping anyways...but the 88 have a rear steer or something so the rear suspension is a little different so if you upgrade to dics you can convert to the typical honda rear...the 91 cluster will fit all you need is the hood from a 90-91 the 88-89 has the short cluster..also just so you know the auto and manual clusters work too, I have an auto cluter with a tach in mine Not sure about the wiring but you might need to change a little to use the newer cluster but you can find that info on here easily
Old Dec 26, 2006 | 11:29 AM
Drew17th's Avatar
Default Re: 88 crx hf.. quick question (Loserkidwac)
so i need to change to like 90 or 91 rear disk and all the normal suspension will fit??? and what about the hood??? so the cluster and the cluster housing will fit the dash of the 88???? i dont really care about weight of the rear disk either lol.. im putting a 200+ whp motor in it so a few pounds does not matter
Old Dec 26, 2006 | 11:57 AM
Yea, I think the rear LCAs are different, but double check i haven't had personal experience with it, the rear shocks are different for 88 than the 89-91, I just assume its how they mount to the LCAs, should be able to correct since the LCAs for 89-91 drums and discs are the same and i believe 90-93 teg share the same LCAs...for the dics look for the 90-91 Si or EX or grab them from a 90-93 Teg, and yes the cluster and hood will fit the 88 dash..
What motr you planning on swapping in?
Old Dec 26, 2006 | 12:03 PM
Suck my DX's Avatar
wait there were EF tachs with a stock shift light? tight
Old Dec 26, 2006 | 12:10 PM
Drew17th's Avatar
Default Re: 88 crx hf.. quick question (Suck my DX)
i am putting a jdm R block rebuilt with shot peened rods, arp rod bolts with OEM oversized .25 over pistons... B16 head with supertech valvetrain, high compression supertech valves, type r IM and jdm R 4-1 header, with m22x cams....
Old Dec 26, 2006 | 12:13 PM
Suck my DX's Avatar
do you think youll hit 200 with that setup? what are you using to tune?
Old Dec 26, 2006 | 12:14 PM
Drew17th's Avatar
well ill be dyno-tuning with crome... those r just the big parts.. i mean i hope to get portmatch and adjustable cams and little things... but from what every1 is saying ill be able to hit 200's....
Old Dec 26, 2006 | 12:24 PM
88CRX951's Avatar
I OLD SKOOL
Are you sure 90-91 cluster will work? I have an 88 Si but had to convert all my wiring to 90-91 and i don't think my 88 cluster will work with 90-91 wiring
Old Dec 26, 2006 | 12:28 PM
Suck my DX's Avatar
Default Re: 88 crx hf.. quick question (88CRX951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88CRX951 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure 90-91 cluster will work? I have an 88 Si but had to convert all my wiring to 90-91 and i don't think my 88 cluster will work with 90-91 wiring</TD></TR></TABLE>
yeah itll work...most of the wires are in the same location...its only a few pins that need to be rearranged
Old Dec 26, 2006 | 12:29 PM
marquisdee1018's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">wait there were EF tachs with a stock shift light? tight</TD></TR></TABLE>
Yeah the shift light is just a little green arrow. Mine has worked for a while.
Old Dec 26, 2006 | 12:31 PM
Suck my DX's Avatar
Default Re: 88 crx hf.. quick question (marquisdee1018)
dope...i hope my hf comes with one
Old Dec 26, 2006 | 12:33 PM
89efDUSTY's Avatar
On my 84 CRX the shift light was orange... fuel economy all the way
kslimm0714
Jun 14, 2006 09:29 AM
Evolution Type R
May 2, 2006 11:43 PM
SupraRXZ
28
Apr 15, 2006 06:08 PM
SiR Inspired ED7
Feb 13, 2006 09:43 PM
firstgenrex
Nov 13, 2003 09:35 AM
