what do i need left? motor swap
i just picked up a b16a2 longblock and wondering what mounts i need to install into my ek. i'm probably going to get the innovative mounts, if not hasport mounts.
Modified by Battle23 at 5:02 PM 12/26/2006
http://www.phear7imports.net/trey/6gen/
they did the swap and tell you what mounts, the 2nd picture is where your alternator mounts... which should have been included with that engine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drhonda »</TD></TR><TR><TD CLASS="quote">http://www.phear7imports.net/trey/6gen/
they did the swap and tell you what mounts, the 2nd picture is where your alternator mounts... which should have been included with that engine</TD></TR></TABLE>
it did, just wasnt bolted on.
so for the mounts, i just need the rear tranny mount braket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">u need the rear L bracket off the 99-00 civic si</TD></TR></TABLE>
50827-S04-N10 that right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch-E-vanish »</TD></TR><TR><TD CLASS="quote">you need 99-00 si t-belt side bracket that bolts up to the block(not mount), and 99-00 si rear brackect.. you can reuse the trans bracket they're the same. that'll be all </TD></TR></TABLE>
Is the bracket i posted not it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle23 »</TD></TR><TR><TD CLASS="quote">
Is the bracket i posted not it?</TD></TR></TABLE>
Why don't you ******* check?
People don't know everything by a part number, it's got a name - look into it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
That's why i posted the ******* picture
Oh, the picture, my bad, that ******* explains everything.
Hey, here's a pic of a civic that me and my friend were building, ITR-T.
You know what part # that BOV is or that charge pipe is (off the top of your head of course)??
http://s82.photobucket.com/alb...3.jpg
You get my point?
</TD></TR></TABLE>Oh, the picture, my bad, that ******* explains everything.
You get my point?
You get my point?</TD></TR></TABLE>
I didn't ask for the part # of it...I asked if that the right PART
I didn't ask for the part # of it...I asked if that the right PART</TD></TR></TABLE>
By giving the part number...
What's the difference between giving somebody a part # and asking them what part it is or giving them a part name and asking them what part number it is?
Whatever though, I don't wanna argue though you can keep "trying to prove me wrong" if that is what in fact you are doing. I simply had a point to make, if you don't get it, that simply reflects on your intelligence. I got **** to do, peace.
Whatever though, I don't wanna argue though you can keep "trying to prove me wrong" if that is what in fact you are doing. I simply had a point to make, if you don't get it, that simply reflects on your intelligence. I got **** to do, peace.</TD></TR></TABLE>
good don't come back
stop whining...just get the 99-00 stuff and you will be set...end thread
</TD></TR></TABLE>stop whining...just get the 99-00 stuff and you will be set...end thread
is the rear L bracket and tranny bracket the samething?
so far...
-driver, passenger, tranny mount from hasport/innovative
-99-00 si rear tranny bracket
-rear L bracket?
-driver side mount bracket (the one i posted first?)
so far...
-rear L bracket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle23 »</TD></TR><TR><TD CLASS="quote">is the rear L bracket and tranny bracket the samething?
so far...
-rear L bracket?
-driver side mount bracket (the one i posted first?)</TD></TR></TABLE>
no...one is on the back of the motor one is on the tranny...3 mounts 3 mounting brackets....make sense?
use 99-00 rear and driverside brackets and the stock tranny bracket
so far...
-rear L bracket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">
use 99-00 rear and driverside brackets and the stock tranny bracket</TD></TR></TABLE>
finally, that's all i needed to know. thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Battle23 »</TD></TR><TR><TD CLASS="quote">Is the bracket i posted not it?</TD></TR></TABLE>
to tell you the truth it does look JUST like it is,im almost certain it is, but im not to sure just by looking at the pic dont wanna give you wrong info.
EG6Boy702
33
Apr 27, 2009 03:55 PM
D16SohcVtec
Aug 12, 2008 08:03 AM
siregcivic
May 20, 2008 08:24 PM
