Master Cylinder Issues
Old Dec 26, 2006 | 07:00 AM
gophat's Avatar
Default Master Cylinder Issues
I Got a new master cylinder to put on my 88 crx... the 2 lines that go into the MC are stripping... i already have the new parts put this is slowin me down... i tried wd40 but it isnt workin... how much do these lines run... im about to cut em off.... any ideas?
Old Dec 26, 2006 | 10:18 AM
dr_latino999's Avatar
Default Re: Master Cylinder Issues (gophat)
Snap-on Brake line wrench, works miracles. Almost stripped my brake lines using the wrench you get at Discount / Autozone
Old Dec 26, 2006 | 11:21 AM
Loserkidwac's Avatar
Default Re: Master Cylinder Issues (dr_latino999)
grab one of these wrenchs(pic just for reference) the size is 10mm..you can get a craftsman one at sears that has a 10mm on one side and a 12mmon the other side, its a couple bucks but will save you any time you have to remove a brake line, I used it the other week at the junk yard to remove a MC and a Prop. valve, so like 8 brake lines a nice snap of the wrist and they all broke loose without a problem
If you want some brake lines for cheap i can check out the local yard(PM me if you are interested), or I'd say check one near you...Matt
Old Dec 26, 2006 | 12:23 PM
prcivic91's Avatar
if they are stripped you want to use a good vise grip and a propane torch. you are going to clap the line with the vise grips and then heat up the line with the torch. the heat will loosen up the rusty line and help you remove it. the reason for clapping it first is if the vise grip falls you don't want to be trying to stick your hand in there after you heated up the line. I have done these a lot when removing the brake lines it works great.
Old Dec 26, 2006 | 12:34 PM
Seatown's Avatar
Default Re: Master Cylinder Issues (prcivic91)
^^ Get that wrench posted above!!! Same thing happened to me I almost stripped the bolts. I got the wrench and I finished up my Master Cylinder. Like it was said above the size is 10mm.
Old Dec 26, 2006 | 04:25 PM
Crx Jimmy's Avatar
Default Re: Master Cylinder Issues (Loserkidwac)
definitely get the brake line wrench, also use a wire brush to remove corrosion behind the fitting. the fitting spins on the line so if there is corrosion on the line it cant spin as well
Old Dec 26, 2006 | 05:53 PM
goosane's Avatar
flare nut wrench ftw. i would avoid using a vice grip unless abbbbbbbsolutely necessary. even after the previous owner stripped the nuts on my mc, the fnw still gripped it and took it off fairly easy. now i won't touch any brake line without one. good luck
uses0ap
Sep 21, 2008 08:19 PM
lollypopking
Jan 16, 2005 09:51 PM
C2Imports
Oct 6, 2004 08:50 PM
bluecrx
Feb 1, 2003 03:51 PM
sporkcrx
Jan 10, 2003 09:57 AM
