89 civic stalls after about 5 miles of highway driving?
Old Dec 26, 2006 | 03:39 AM
go4wheeling's Avatar
Default 89 civic stalls after about 5 miles of highway driving?
My 89 civic stalls after I drive it for about 5 miles on the highway... after it stalls it will not start for about 5 mins. I dont think its the fuel pump because I can hear it turn on everytime you turn the key and I just replaced it. Has anyone had this issue before?
Thanks
Old Dec 26, 2006 | 03:50 AM
92civicfreak's Avatar
fuel filter?...
do you have adiquite fuel pressure?
maybe it has to do w/ your engine temp... maybe it is running too hot & your ecu doesn't know it... check the ECT sensor
Old Dec 30, 2006 | 09:08 AM
Default Re: (92civicfreak)
I dont think that its the fuel filter becuase its consistant. I work about 6 miles from my house and i can almost make it to work without is stalling.... and its not over heating the temp is normal.
Modified by go4wheeling at 10:19 AM 12/30/2006
Old Dec 30, 2006 | 09:16 AM
rayzian's Avatar
Default Re: (go4wheeling)
any CELs?
Old Dec 30, 2006 | 09:20 AM
Default Re: (rayzian)
my check engine light is on but its been on for about a year now.
Modified by go4wheeling at 10:33 AM 12/30/2006
Old Dec 30, 2006 | 12:56 PM
ChickenH's Avatar
could be a lot of things. ignitor would be my first bet . because when they get hot they open up a circuit and quit working , distributor,wiring, or mfi relay, but we would need more information to get a better diagnosis.
Old Dec 30, 2006 | 01:09 PM
wood 1's Avatar
Default Re: 89 civic stalls after about 5 miles of highway driving? (go4wheeling)
I had this problem and it got progressively worse. Finally it would not restart at all. Turned out to be the coil.
Old Dec 30, 2006 | 07:08 PM
Default Re: 89 civic stalls after about 5 miles of highway driving? (wood 1)
do you know how i can test my coil?
Old Dec 30, 2006 | 08:06 PM
Tippyman's Avatar
First off, check the CEL to see what it is!
Look at the ECU and it will blink the code for you.
JamPGE
Sep 2, 2015 12:29 PM
forevermemorabl
Oct 28, 2013 04:54 PM
Rick1t
27
Aug 16, 2013 06:59 AM
blk_eg4
Aug 3, 2006 08:27 PM
vlade31
Jun 21, 2005 06:03 PM
